Question about Vulcan Heating & Cooling
Vulcan quasar40 keeps turning off we think it has a timer stuck on please help
  • 53 Answers
Probably a bad clock, they **** out from all the heat up there. Have a gasfitter or electrician bypass it. (2 wire plug behind fan lever) - unplug it, cut off from the loom going up to clock, crimp the ends together on the plug you have just cut off, plug it back in. Your heater is now a manual with no dodgy clock.
Posted on Jul 16, 2009
2002 Kawasaki VN 1500 Vulcan Classic will not engage
Hi, Anonymous and the usual suspects are:
1. Clutch cable adjusted too tight.
2. Pressure plate center screw adjusted too tight
3. A broken clutch rod.
4. Slave cylinder piston stuck.
5. Clutch plate missing from the clutch pack.
6. Clutch plates have worn past minimum specifications.
7. Clutch plates crystallized due to incompatible oil.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Clutch not fully engaging Help Kawasaki Vulcan Forum Vulcan Forums
clutch will not engage
Kawasaki Vulcan 1500 Classic Fi Service Manual
OEM Parts for Kawasaki
2002 Kawasaki Vulcan 1500 Classic Owner Manual
May 22, 2014 | 2002 kawasaki VN 1500 Vulcan Classic
1994 Kawasaki VN 750 Vulcan will not shift
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Stuck in neutral or will not shift to first gear Kawasaki Vulcan 750 Forum...
1996 Vulcan classic trans problems PLEASE help Kawasaki Vulcan Forum...
Kawasaki VN 750 Service Manual
1994 Kawasaki Vulcan 750 Owner Manual
Oct 13, 2013 | 1994 kawasaki VN 750 Vulcan
1986 Kawasaki VN 750 Vulcan gas coming out of the exhaust
1. Fouled spark plug.
2. Fuel injector stuck open.
3. Carburetor float needle valve, not seating.
4. Carburetor float stuck open.
5. Exhaust valve stuck open.
6. Exhaust valve bent.
7. Fuel valve leaking back through the vacuum line.
fuel leaking out my exhaust Kawasaki Vulcan 750 Forum Kawasaki VN750 Forums
Raw Gas Coming Out Exhaust Kawasaki Vulcan Forum Vulcan Forums
1989 Kawasaki Vulcan 750 Owner Manual
Jul 31, 2013 | 1987 kawasaki VN 750 Vulcan
2003 Kawasaki Vulcan 1500 Nomad sticking clutch plates
Hi, Anonymous if your bike has been sitting for weeks or months and you get it started, put it in 1st gear, it lurches forward and stalls. Your clutch has bonded from surface rust on the steel plates due to condensation from running hot and shutting down in a cool environment. The easiest way to remedy this situation is to push start the bike in gear, shift and drive it normally until it reaches operating temperature and you will be fine. In severe cases, the clutch will have to be removed and disassembled, the clutch plates decontaminated and reassembled and installed.
Clutch is stuck Vulcan Bagger Forums
Jerk when shifting into first gear
Kawasaki VN1500 Service Manual
2003 Kawasaki Vulcan 1500 Classic Owner Manual
May 19, 2013 | 2004 kawasaki Vulcan 1500 Nomad
2005 Kawasaki VN 800 Vulcan Classic woodruff key keeps breaking
Hi, Turtle the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Broken Crank woodruff Key Keeps Breaking HELP ATVConnection com ATV...
Thread 550 keeps breaking woodruff key
KAWASAKI VN800 Service Manual
2005 Kawasaki Vulcan 800 Classic Owner Manual
Apr 09, 2013 | 2005 kawasaki VN 800 Vulcan Classic
2003 Kawasaki VN 1500 Vulcan Classic how to unstick stuck carb floats
Hi, Anonymous for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
Have read MANY posts on carbs stuck floats need advice still Kawasaki...
How To Kawasaki Vulcan VN800 Carburetor clean rebuild 1995 2006
Apr 06, 2013 | 2003 kawasaki VN 1500 Vulcan Classic
1994 Kawasaki VN 750 Vulcan transmission stuck in neutral
Hi, Johnwsmith24 and the usual suspects are:
1. Improper clutch adjustment or not disengaging.
11. Shift lever loose on the shift shaft.
http://www.vn750.com/forum/26-transmission-rear-end/10507-shifter-stuck-neutral.html
Stuck in neutral lost all gears Kawasaki Forums
May 01, 2011 | 1994 kawasaki VN 750 Vulcan
How do i switch on the volcan dishlex 100s dishwasher
Hi just read your posting.Do you mean Vulcan Dishlex 100s?Have you got 1 big timer knob on the front right and 1 small knob to the left of the big timer knob?Or have you only 1 big timer knob?Please reply with additional information and I can help you solve this problem.
Jul 23, 2010 | Dishwashers
My TV wont stay on....
it sounds more lke the power supply is gone than a timer being stuck
Oct 25, 2008 | Samsung HCM422W 42" Rear Projection...
Heating & Cooling Logo
325 people viewed this question
Top Vulcan Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
