Question about Minolta Di1811p Grayscale Copier
Upon turning on the machine, machine display error code M4:00187754. please help.. tnx dindo
  • Minolta Master
  • 6,161 Answers
M4 is maintenance counter, you clear it in service mode.
Posted on Jul 19, 2009
Healthstream Evo Treadmill. When I turn machine on, all I get is 3 Beeps. The screen display has 8 rows,The 6th row is fully on. The bottom the alpha numerals,the center led of each unit is also lit.
Sounds like a fault in in the treadmills computer system the beep3 are error alert sound meaning somethings has gone wrong inside or the motor is reporting jamb fault code etc and its displaying with the lights upon the display board an error code a treadmill enginer will understand
Jul 12, 2016 | Washing Machines
Can any one help m please, I have a Konica minolta bizhub C450 and i have a malfunction code C152, can any one tell me how to fix it please as soon as possibl thanks to all
i found this after a brief search
Straight from the service manual....just use the last 4 digits when doing a search, makes it easier to find the specific code as not all manuals are the same in how the code is displayed.
CC152 ROM contents error upon startup (Scanner)
• A fault is detected in a sequence of ROM contents check of the PWB-C during starting.
16.5.79 CC151: ROM contents error upon startup (MSC)
16.5.80 CC152: ROM contents error upon startup (Scanner)
16.5.81 CC153: ROM contents error upon startup (PRT)
16.5.82 CC154: ROM contents error upon startup (PH)
1 Check the ROM version. - -
2 Rewrite the firmware. - -
3 Replace the appropriate board.
TSB entry
Description
C-C152 at power up, the counters display as 0 and the operation panel display is in Japanese.
Solution
CAUSE: Main body firmware is corrupt.
SOLUTION: Flash or re-flash the firmware to the latest level.
As for the 2152 code,
16.5.6 C2152: Transfer belt pressure welding alienation
Dec 04, 2014 | Konica Minolta bizhub Office Equipment &...
I have a CE error code on my Hayward Pool heater. This happened after a heavy rain. Should I try a hairdryer?
According to a Hayward manual the CE error code is a communication error. Here is quote, "If communication between the ignition board and the display board is not established
within 3 s of power-up an error will be displayed. After communication is
established, if it is lost for 30 s, the error will be displayed. The error code will
be cleared upon a valid data exchange between boards."
I don't think you can do any harm by turning the power off, opening the cover and drying everything out the best you can. In addition, if you carefully unplug and then replug each of the connectors then that may also help correct a communication error.
I hope this helps and please vote on this answer. Thank you.
Aug 26, 2011 | Hayward 250kbtu Ng Pool Heater - Inground
Error code LO
If an "L" appears upon the electronic display area of your Maytag washer, it is indicative of the washing machine's lid failing to lock properly. When an "L" error code appears, it is normally caused by one of two issues, a faulty lid locking switch, which is designed to hold the lid securely closed during the wash cycle, or a faulty lock solenoid sensor, which is designed to display a warning signal that the lid is not locked securely. Replacement of the needed part should correct the issue and the error code should disappear.
If the issue persists, there may be an issue within the machine's electronic display board that should be investigated by a Maytag approved repair technician.
Hope helps.
Jul 28, 2011 | Maytag MAH8700A Front Load Washer
General error in epson stylus t13
HOW TO FIX MY PRINTER, IT DISPLAY A GENERAL ERROR, AND BOTH RED AND GREEN LIGHT IS BLINKING.PLS HELP ME..TNX
Jan 12, 2011 | Epson Office Equipment & Supplies
My canon photocopy machine displays an error code presenting as (E 000602 - 0003)Please help me solve this problem.
Hi these means that you have HDD trouble, and it needs to be changed and upload the system on it - CALL SERVICE.
Aug 19, 2010 | Canon Office Equipment & Supplies
Xerox Workcentre C226 - Error H5-01
This might help, but I don't know how to put it in tech mode.
"The fuser error reset code will reset the machine so it will run after the problem is fixed.First remove any jam in the fuser then enter tech mode;
press program, * ,clear, * enter 1 4 press start then turn machine off and then back on."
Jul 29, 2009 | Office Equipment & Supplies
Minolta EP 5000 error code c0b63
Hello sir; that code means sortr bins problem, I belived when you moved hit somewhere soter bin out of track( not line up).
Mar 22, 2009 | Minolta EP4000/5000 CS/PRO Copier
We have a whirlpool 6th Sense AWM 6145/3 which has just started stopping during the wash cycle and on the digital display the letters F H come up. We rent our property and have moved several times and have...
FH is the code for no water flowing in...
is there water flowing in?
if there is none, the water solenoid is the problem,
if there is water going in, then the flow switch is the problem.
here is the transcript from the web..
FH ERROR CODE
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves
will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow sensor has
detected 48liters of water passing through it, but has not detected the pressure switch
trip, the valves will be turned off and the error code will flash.
and here is their solution
water source opened
flowmeter
pressoswitch
wiring to valves, pump,
flowmeter, pressoswitch
hoses
either one of those parts...
tnx 4 using fixya,
drcool
Sep 13, 2008 | Whirlpool Washing Machines
My canon iR3300 is displaying error code E000002-0000. Please help.
My canon iR3300 is displaying error code E000003-0000. Please help
Jul 30, 2008 | Office Equipment & Supplies
Minolta Di1811p Grayscale Copier Logo
129 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
