Question about Garmin nuvi 2589LMT 5" GPS with Built-In Bluetooth, Lifetime Map Updates and Lifetime Traffic Updates
Micro sd card wont click into place garmin nuvi 2589
  • Garmin Master
  • 2,130 Answers
On some units, they won't click. You slide the micro SD card into the slot and you will feel a slight resistance. Continue to slide the card in until it stops. It will only slide in one way. This is exactly how the micro SD card slides into a standard SD adapter. There is no click. If you connect the GPS to a PC using the USB data cable, your PC should recognize (2) memory devices; (1) The GPS and (2) the SD card. It may take a few moments. Wait a few minutes until you see both appear in Windows. Always select EJECT or SAFELY REMOVE before you remove the USB data cable.
Posted on Mar 08, 2016
  • 26 Answers
SOURCE: SD Card slot Garmin nuvii 260
I have found that waypoints, routes and directions work only when I load it on the unit itself as opposed to the SD card. The SD card works more like an expansion slot for pictures or maps.
When you open up Mapsource you'll see the map on the right and the pane on the left, above the pane there are 4 tabs (Maps, Waypoints, Routes and Tracks). As you select a map or create a waypoint, route or track. It will put a number in parenthesis which will increase in numbers as you add an item corresponding to each category, for example if you create a waypoint. So once you have done that, click on the TRANSFER tab in the Menu selection bar and choose SEND TO DEVICE. A window will pop up that will say...Device: with a drop down menu if your Garmin unit has an SD card in it, if not it will just show the Garmin unit. Then right below that there will be a section that says WHAT TO SEND with 4 check boxes that will say Maps, Waypoints, Routes and Tracks. Make sure that you have selected the Garmin unit, not the SD, and the waypoints, routes or tracks you want to send. I hope this solves your problem or at least points you in the right direction...
Posted on Jun 25, 2008
SOURCE: Garmin nuvi 260
Re: Not sayinstreet names.
After you turn on your unit touch the wrench icon in the bottom right of the screen, this will take you to a menu which features "Settings" in the upper left of the screen. Touch "settings" and scroll down to "language" by using the up and down buttons in the lower right of the screen (down 1 should do it). Touch "Language" and in the voice category find and select "American English - Jill (TTS)". This is the voice that will give you Text To Speech (TTS) speaking the street names in English. If you prefer Spanish or French, find the appropriate catergories with "(TTS)" beside them - "Espanol Americas - Paulina (TTS)" and "Francais Canadien - Julie (TTS)" respectively. Any other selection will only give directional instructions such as "turn left in XXX".
After you have selected your voice press "OK" and back out to your main menu showing "Where to?" and View Map".
Now, when you navigate, you should hear an American female voice giving you directions by street name - assuming your volume is high enough to hear it.
RE: The computer icon displaying when you try to use your unit in the car with the 12 VDC cord.
You probably have a problem with the cord. The pin length in the USB style connector is critical and if it doesn't match up just right the GPS thinks it is hooked up to a computer. If you know someone who has a Garmin NUVI try using their cord and see if you have the same problem. Either way, call Garmin and see if they will send you a replacement cord or otherwise help fix the problem.
Posted on Nov 03, 2008
SOURCE: Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
Posted on Apr 01, 2009
SOURCE: garmin Nuvi 760 memory card
Does the Garmin Nuvi 760 require an additional memory card for normal use?
The simple answer is : no it does not need and SD card to work
Posted on May 22, 2009
SOURCE: I have a Garmin Nuvi 200 and cannot load 2010 update
Install the SD Card. When you select your maps and transfer them to the device, make sure the Nuvi is plugged into the USB. When you are on the screen to "Find Device", select the dropdown menu and you should see the drive letter referencing your SD card. Select that and you should be all set.
Posted on Jul 22, 2009
DELETING MAPS ON NUVI 40 LM
Plug your GPS into your PC, it will mount as a hard drive. You can then open the folders and delete content. As easier solution is to put a 8gb micro SD card in the SD card slot. Garmin Express will allow you to put additional maps on the SD card.
Mar 22, 2017 | Garmin Nuvi 40Lm - Gps Receiver
Nuvi2555LMT
The micro SD card has to be between 4-8gb. Garmin Express is used to load the South American maps. Garmin Express can be downloaded from Garmin. Once installed on your PC, plug your GPS into your PC. The program should give you the option to install the South American maps to the SD card.
Dec 31, 2016 | Garmin nuvi2555lmt nuvi 2555lmt
How to upload map from computer to sd card for Nuvi 1310
1.connect your device to pc via USB
2.it will open as GARMIN mass storage on your pc
3.open GARMIN drive from my computer
4.if windows 7, look left side Organize->Folder and search option
5.click View Tab ->click show hidden files folders
6.uncheck hide protected operating system file.
7.click ok
8.open .system folder and delete gmapprom.img and paste your india map file and rename it to gmapprom.img
9.copy JCV and SID folder to GARMIN main folder as shown in the image.
thats all
Feb 23, 2014 | GPS
I paid for a costa rica map thru Navsat. I need to download it to my Garmin. ow do I do that?
Typically downloaded maps can simply be installed by placing the downloaded file in a certain directory on your supplementary memory - in this case a micro-SD card. You can either plug your Garmin into your computer with a USB cable or use a SD card slot to do this.
You want to place the (unzipped) gmapsupp.img file under e.g. E:\Garmin\ after backing up any data on the storage device you are writing to. If its a new SD card you will need to create that folder.
You can also save yourself some money by downloading free maps here: http://garmin.openstreetmap.nl/
Jan 13, 2014 | Garmin Nuvi 265W GPS Receiver
Micro sd card too big for garmin gps nuvi 1450
A micro SD card is the correct memory card for the 14xx series. A 2 GB should be just fine. Some units can not handle a large memory SD card. This has nothing to do with the physical size however.
Are you sure it isn't a micro SD card that is inserted into a standard SD card adapter? A standard SD card is much larger and will not fit into the 14xx series. Look at the end of the SD card that does not have the gold pins and see if there is a ridge where the micro SD card may be inserted into the larger standard SD adapter. Using a fingernail, you can slide the micro SD card out from the SD card adapter. Also, the micro SD card will only insert one way. Try flipping it over and inserting it again, always with the gold pins facing the Nuvi.
Apr 06, 2013 | Garmin nuvi GPS
No detailed maps found that support routing.need to download software on to micro sd card for garmin nuvi 205
The solution to the "No detailed maps that support routing" problem can be found at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
To set up a map on the micro SD card you can follow the instructions on http://www.fixya.com/support/r5628920-update_garmin_satnav_maps Don't download directly to the micro SD card as it won't be recognised by your satnav. Download to the computer and install from the computer to the card as described at the above link.
Apr 11, 2011 | Garmin nuvi 205W GPS Receiver
New Sd CArd-8gb. Trouble completing upload maps.
I have uploaded maps to a SD micro card from my Nuvi 250 to my Nuvi 205 but the 205 wont give me the option to select maps from the SD Card.
Can some one please help.
Thanks in advance.
Jul 08, 2009 | Garmin Nuvi 660 GPS Receiver
Garmiin nuvi gps,
The device uses SD cards actually. They will not however work with TOPO maps or Bluechart. They are primarily for loading media or city street maps for other country's.
Jan 14, 2009 | Garmin 010-C0495-00 TOPO Canada - Manitoba...
Garmin nuvi 2589LMT 5" GPS with Built-In Bluetooth, Lifetime Map Updates and Lifetime Traffic Updates Logo
260 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
