Question about Canon ZR80 Mini DV Digital Camcorder
Hello - Canon ZR80 - auto shut off
Is there away to keep the "Auto shut down" from engaging - I'm plugged int o power - wall power and it keeps shutting down whenIm using the camera???
Posted on Apr 19, 2008
If you're trying to use the camera as a webcam, just remove the tape. The auto power-off is a safety for keeping the tape from getting damaged.
Posted on Dec 04, 2007
Canon powershot elph 320 hs
Hi Doug,
You are right in identifying the cause of the pre-mature shut-down of the camera during video recording. Battery saving features (auto-shut down) detect the camera as idle while you are recording. you could do two things to avoid this;
1. A short term practice is to manipulate the camera to stay on by using the zoom button, taking a snap-shot or anything like that from time-to-time, before the 2 minutes is up. This will keep the camera awake long enough for you to record a good length of video.
2. The second and permanent option is to program the camera - just as you mentioned. You can do that by opening the menu and under camera setting , scroll down till you find the auto-power save. Change the time to your preference
Please note: You have to switch off your camera as soon as practicable while the auto-switch-off time is set at a bigger value to conserve the battery. otherwise the battery will be drained quicker than you imagine.
I hope this helps.
Sep 01, 2014 | Canon Cameras
Auto power off
Link to user manual
No you can't turn off this feature
Nathan Petersen June 17th, 2005, 04:03 PM Is there away to turn the auto power off off. I dont think there is, just thought I'd ask, thanks. Don Palomaki June 17th, 2005, 08:47 PM Not on the original XL1. It will drop into STANDBY from PAUSE if there is a tape in the transport after around 5 minutes. If there is NOT a tape in the camcorder it will not not drop into STANDBY but will remain operating as a camera. Xander Christ June 17th, 2005, 09:25 PM Canon suggests that the only way to keep the XI from shutting off is to use the AC adapter as the power source, not the battery. I haven't tried it, so I don't know if it's true. Don Palomaki June 18th, 2005, 07:33 AM True - in that when using the battery, the camcorder will shut down when the battery runs out of available charge. However, using the A/C adapter does not prevent the XL1 from going into standby if a tape is in the camcorder. Nathan Petersen June 18th, 2005, 04:52 PM Canon suggests that the only way to keep the XI from shutting off is to use the AC adapter as the power source, not the battery. I haven't tried it, so I don't know if it's true.
No it still does it with the AC adapter, Im not even using the battery. It makes no sense to have the auto power off when shooting indoors while using the AC adapter, its just stupid. Don Palomaki June 19th, 2005, 05:59 AM Again, the key point is having a tape in the XL1. After about 5 minuts it goes into Standby mode (not the same as turning the power off with the dial). This is a carryover from pure consumer camcorders - to save battery and reduce damage to tape and head wear from a camcorder left in pause mode for a long time.
Pro users complained, so the XL1s had an option to disable this feature so that only the tape transport (VCR portion) is turned off after 5 minutes, the camera head continues to run. link to above thread
Dec 02, 2007 | Canon Optura Xi Mini DV Digital Camcorder
I cant change the Auto Off feature
You should be able to press the Auto Off button and it cancels the automatic option. Hold it down and while keeping pressure on the button, pull the power cord from the Wall. keep holding the button and reinsert the Power Cord once again. Lift up and see if it did a Reset.
Jan 24, 2014 | Keurig Platinum B70 Coffee Maker
Zr80 moisture problem solution ?
Friend, Remove whatever you can without using a screwdriver, ie, battery and card etc. Then use your hair dryer on it without heat. Keep blowing air into it for sometime. You can do it in spurts too. Stop and go procedure. Then, reinsert all the items that you removed. Power on and see if you still get the moisture icon. If yes then you need to take it to a repair shop. The circuitry may be faulty.
Nov 27, 2009 | Canon Video Cameras
1985 fordf-150 inline6 wont shut off
if it seems to be stumbling when you turn it off but keeps running then you likely have carbon buildup on the valves, pistons or plugs .. the carbon stays hot and keeps the engine running even without spark .. usually if you hit the gas once it cools the hot carbon and the engine quits .. i suspect your f150 is never run fast .. a romp in passing/second gear once in a while usually keeps it clean .. there is special cleaner you can run thru to clean out the carbon .. you can get that an any auto parts store .. make sure the plugs are the correct heat range .. plugs that are designed for oil burning engines stay cleaner but may be too hot .. that can cause the same problem ..
now if your engine runs on smoothly with the key off then i would suspect a problem with the ignition switch or wiring
Sep 14, 2009 | 1985 Ford F150
Auto Print off...
Just press your on/off button once,then it will set to auto print.If you keep the on /off button press in for a few seconds it will shut down.By pressing it once it switch between auto print on and off.
I agree this is a funny setting on this model.
Feb 03, 2009 | Canon FAX-JX200
Processing auto configuration
Check your settings in "Power Options Properties".
Control panel/ power options/ advanced/ under power buttons make sure you have "shut down" when you press the power button on your computer.
I hope I am understanding your problem correctly. If not pls. explain what you mean by and when processing auto config. keeps flashing. Is there a black screen or a windows interface?
Nov 18, 2008 | Acer AL1711 17" LCD Monitor
When i playback my recording on my canon zr80 the image is distorted
then it is shaking while you take the picture
keep the hand steady and use auto mode for clear pictures
Aug 01, 2008 | Cameras
Canon ZR80 Mini DV Digital Camcorder Logo
1,174 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
