Question about Garmin GPSMAP 60CS GPS Receiver
60CSx will not acquire satellites
My 60SXc worked ok the first time I used it about 3 days ago,however today it would not acquire satellitess and the time and date were incorect and could not be adjusted. I see others have had this same problem and said their GPS showed a 00 version software and they downloaded a fix from Garmin. How do I find out what version of software my unit is loaded with.
  • 22 Answers
To find the firmware version go menu, menu, setup, system, menu, software version.
this will show version and unit id
also the garmin sw should show you this info also
D
Posted on Nov 21, 2007
SOURCE:
Gps 60csx don't get satellites signal level
use the webupdater and replace GPSChipsetTypeG file.
Kind Regards,
Silva.
Dec 08, 2012 | Garmin GPSMAP 60CSx GPS Receiver
Need satellite
Go to garmins site and download the fix for this issue. Have fixed several of these. They have the download there. I just fixed one the other day.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Sep 15, 2009 | Garmin GPSMAP 60CSx
No satellites signal
Update/Reload your unit's GPS and sytem software via Garmin page or use Web Updater. Your unit will be functioning again. This problem also occurs if you leave your unit on a dash board in a car and it is exposed to hight temperature.
Mar 08, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Trouble with a gps map 60csx the gps is acquiring sattelited an
Feb 06, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Not acquire sattelites
place the GPS outside with a clear 360 degree view of sky or as much of the horizon as possible and leave it for a few hours it needs to download the almanac from all satellites before doing this
from the Acquiring Satellite page press menu and make sure that the topline of the menu reads "Use With GPS off" if it reads "Use With GPS on" (this means it will not find any SAT's ie for indoor use) press enter to turn the GPS Receiver on
Jan 01, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Garmin 60CSx - Cant find satellites
Try a re-load of the chipset driver. It is available from the Garmin website. I find that it occasionally becomes corrupt.
You can check by entering the "Main Menu" then "Setup" then "System" then press Menu and choose "Software Version".
If the "GPS SW Version" is 0.00 then a reload of the chipset driver will correct the problem.
Cheers.
Dec 29, 2007 | Garmin GPSMAP 60CSx
Garmin gpsmap 60csx won't acquire satellites
I found the solution that fixed my 60CSx. You need to make sure you have the latest chipset installed on your device. Go to
https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00422-00&cID=145&pID=310
and download the chipset type G ver 2.9.
After you have loaded it on your 60CSx, you should be good to go. Just turn it on like you normally do and now you'll see your device retrieving locks w/ the satellites.
Let me know if this helps you out.
Charles
Dec 10, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Go to the Garmin Web site's home page, avoid staring to long at the hot chick and click on "On The Trail" .. "Mapping Handhelds" .. scroll down to the second row far right and click on the 60CSx. You will then see the 60CSx page, look to the right and click on "Updates & Dowdloads", on doing so you will now see four downloads to choose from. The one you will need is "GPS Chipset Type G Ver. 2.90 as of Nov 27, 2006" if you follow this you shouldn't have any problems. If however you do i'll keep an eye on this page and try to help, this is my first GPS and also had the same issue.
Sep 17, 2007 | Garmin GPSMAP 60CS GPS Receiver
Not acquiring satellites
Go to the Garmin Website and see if there is a Software update Available Hope this helps ttech
Jul 24, 2007 | Garmin GPSMAP 60 GPS Receiver
Garmin GPSMAP 60CS GPS Receiver Logo
209 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
