Question about Kenmore Dishwashers
My kenmore dishwasher, model 15822, just stopped working. The quick rinse light is blinking. The only other buttons that work are the pots & pans light which blinks when pushed, and the cancel button which will run through the 2 minute cancel cycle.
These are known to develop sticky switch contact pads. They stick in the contacted position and stifle the panel. Sometimes heat can be applied with a hair dryer to release them and make the unit function again. This is more than likely a temporary fix. New panels are available for about $165 to $200.
Posted on Dec 28, 2011
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Pots and pans and normal wash blinking
Try resetting it. Locate the switch in your breaker box, and flip it off- then on again. Hope that works!
Aug 09, 2009 | Kenmore 13743 Staimless Steel Built-in...
The Pots Pans button flashes and won't let me change it
Go to your circuit breaker panel and turn off the circuit that feeds you dishwasher. Leave it off for three minutes. This will reset the program and should solve your problem.
Apr 04, 2009 | Kenmore 15634 Built-in Dishwasher
Blinking quick rinse and lock on lights
Try holding down the "lock" button.It may be the way to unlock the problem.
May 26, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Quick Rinsw button blinking
I may have fixed my similar problem- I opened up the machine to get access to the control panel as tech17 advised- then in addition to disconnecting the mylar ribbon, I disconnected all the connections to the control panel.... keep in mind to ensure not to confuse any of the connectors you disconnect. Running a cycle at this time... seems as if working.. can't tell if water is running or just the motor- -- HA! -- i confirmed no water being pumped in.... We then found a float switch (Item 30 on schematic) that got loose from its casing on the front interior right lower side... we put that switch into its proper place and now ALL IS WELL!!!! Yippee!!!
Feb 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Feb 02, 2008 | Dishwashers
Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes.
Oct 16, 2007 | Dishwashers
Dishwashers Logo
174 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
