Question about Dryers
Dryer not heating
Ive gota fisher and paykel 3.5kg dryer and it will not heat up what so ever and filter is clean, any ideas?
    Problem Solver:
  • 5 Answers
Check heating element the coils may be broken.
Posted on Jul 16, 2009
My fisher and paykel dryer will not heat
Check all the fuses on the unit with an ohm meter. Also go to you tube for visuals on how to do this
Feb 23, 2015 | Fisher and Paykel Dryers
My fisher paykel dryer is 3 1/2 year old. It works fine on med and low heat. On high heat, it heats up too much and turns itself off
clean the dryer of lint inside and also the vent tube:
http://fixitnow.com/2003/11/appliance-tip-of-day-dryer-disassembly.htm
Nov 06, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Top load Fisher Paykel dryer doesn't get real hot and therefore is very slow to dry clothes. I've checked the lint filter and the exhaust pipe is clear, so air is moving freely through. It seems it must...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Fisher and Paykel SmartLoad DG62T27G Dryer
My fisher paykel electric smart load dryer works fine. it wont heat. I have cleaned all lint out of the dryer. with still no heat. what should I do? Bill,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 24, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Jul 08, 2009 | Fisher and Paykel DEGX2 Dryer
My fisher paykel DEGX1 won't heat up. everything else works fine.
If you have the same I do then it's the circuit breaker on the heating element. You have to take the front of the dryer off: Two screws on the top under the caps. Then lift the top alittle and you'll see the two screws on the front top sheet metal. The front then can be removed by pulling each side out and forward. The orange button is all the way at the bottom. Push and you'll hear it click.
Mar 05, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and paykel dryer
hi
is the filter clean and is there air coming out of dryer if all tis is ok it could be heating element or timer
cheers grant
Oct 21, 2008 | Fisher and Paykel GWL11 Top Load Washer
Wont heat
the sensor may need to be reset. My felt filter had come off but the dryer worked fine until everything filled with lint. Much of the lint was in places you can't get to easily and Fisher Pykel doesn't mention cleaning these areas in their manuals. I know it is to late to help you but it may help someone in the future.
Nov 15, 2007 | Fisher and Paykel DEGX1 Electric Dryer
It wont heat at all. lint trap empty, good air flow
needs a heater rework kit probably. contact fisher paykel and they will pay for the repair.
Nov 02, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Dryers Logo
76 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
