Question about Kirby G5 Bagged Upright Vacuum
My kirby was working fine.cord put out of socket. i reinserted cord and vacuum would no longer turn on. is there a fuse that might have tripped that i need to replace?
I had a simular problem and went and bought a nother than realized that the bag wan't locked into place it wont start unless the bag is locked you may thy that my son just bumped the wall and I guess it just jared it loose I guess
Posted on Jul 19, 2009
  • 357 Answers
It's for sure either the power cord or the switch. Here are a couple of free repair guides that might help out...
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Hope this helps,
Marci
  • 93 Answers
Cord is probably faulty
take off the cover over the plug and plug in an IEC plug ( used on computers) and see if it works
Posted on Jul 16, 2009
I have Kirby vacuum cleaner that all of the sudden won't turn on. I know the power cord has been stepped on a few times through it's life but it doesn't appear to have been pulled enough for it to not get...
Brocken switch could be the problem but power cord most likely check continuety on both wires from the plug to the unit also does have fuse have you checked?
Sep 26, 2017 | Kirby Vacuums
Kirby cord has a short in it
cable overheated at bottom joint, blown wire internally, will have to replace cable. phone 0800 294 4692 for new cable 27.95
Jan 13, 2013 | Kirby Sentria 192006 Power Cord
The unit will not run.
Check cord on machine. Plug in and turn on wriggle cord near powerpoint and then near machine and all over, if it starts and stops the cord needs replacing
May 02, 2010 | Kirby G4 Bagged Upright Vacuum
I was vacuuming my car and the Kirby G4 just stopped
Greetings from GoVacuum,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack, or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Please feel free to email me if you'd like instructions on how to diagnosis the switch or carbon brushes, or if you need to purchase a cord for your G3. Also I can send you a parts diagram of the Kirby should you ever need any other part for it. I have all parts for Kirby in stock, and we are the cheapest price online.
If the cord tested ok, then there are a few other things that may have gone bad. I'd be more then happy to try and help you diagnosis the Kirby further. Please just request a repair clarifiaction here on Fixya with further details.
If this helped you figure out the problem, please rate my repair as helpful. I really do appreciate it, thank you.
Chris J.
Mar 15, 2010 | Kirby G4 Bagged Upright Vacuum
I need to replace power supply. where the cord
Greetings from GoVacuum.com,
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
Chris Jones
Mar 07, 2010 | Kirby Generation 3 Bagged Upright Vacuum
My vacuum kirby turned by itself
The problem was that the piece that you connect to the wall outlet was broken. I purchased a new cord and it is working fine now. Thank you!
Jan 18, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Senteria power will not come on at all
Make sure the bag and the front nozzle are attached all the way. There is a safety switch on the bag and nozzle. If either one of these is not on all the way the machine will not come on.
There is a reset circuit near the cord inlet. Make sure that is not tripped as well. When you plug the machine in listen for a click. If you hear a click and no power then perhaps the circuit breaker is faulty or there is a short in the machine.
Aug 21, 2009 | Kirby G6 Bagged Upright Vacuum
The headlight on my Kirby doesn't work!
A few problems exist in this situation.
A. Is the bulb you put in a genuine kirby part?
If not it is probally not the correct anperage.
B. Are the little medal pieces on the end lined up correctly? If not adjust and retry.
C. The socket the bulb fits into is bad. In that case call 1-800-948-1358 mon.-fri. 9am-6pm est
sat.9am-2pm est and ask for josh or buck to order the socket.
Apr 16, 2009 | Kirby Generation 3 Bagged Upright Vacuum
How to replace a fuse a Kirby Ultimate G Series
There is no fuse in the Kirby. There are few things that you want to check:
1. Cord - most likely cause. It may not be damaged but wires inside may have snapped if it got between doors.
2. Safety switch inside - no easy way to check. We usually just put a new one in and see if it solves the problem.
3. Motor - very unlikely that something is wrong with the motor - those are very hard to kill.
Apr 20, 2008 | Kirby Heritage II Vacuum
Kirby G4 will not start
Check the mains socket with something else.
Oct 06, 2007 | Kirby G4 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
208 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
