Question about Hannstar AH-191D Monitor
Hanns 19 inch widescreen lcd monitor
I have a one inch vertical white strip on my monitor it got hit one day and wont go away what can i do to fix it or do i need to buy another monitor
0 characters
1 Points
Hanns-g JC199d monitor displays 2 messages periodically
install an AGP card into an AGP slot because internal display card does not support high resolution because of insufficient memory . use 8X AGP card for better result . then you can see high resolution ,3D games ,and movies .
Apr 17, 2010 | Hannspree HANNSĀ·G JC199DP LCD Monitor 19...
My montor is going green in place how can i fix it
move the speakers away from it the magnet is pulling the color out of the screen :)
Jan 27, 2010 | LG 19 Widescreen LCD Monitor, 1440X900...
My samsung 19 widescreen got white screen after 2 years can I fix this some how? / Johan
Hi! using analog it seems to work for now but sometimes it blinkes white on the screen,it seems to work better when I have had the screen on, for some hours then it seems to work fine.. But I dont know for how long..
samsung 19 wide.
/ Johan
Oct 21, 2009 | Samsung T190 19" Widescreen LCD Monitor
Hanns-g hc 194d 19 inch monitor
I am already registerd and have my unlock number,but I have forgotten my password so I need new password
Aug 25, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
LCD Monitor takes time to display HANNS.G Model
there is leak capacitors problem inside of your monitor they need to be replace so that your monitor work normaly
May 22, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
No XP driver for Hannspree New york 19 inch monitor
Hi David,
Thanks for the comment regarding what type of computer equipment that you have. The integrated video card that you are using definitely is not designed for the widescreen monitors and will not work properly with the widescreen (as you have noticed). The solutions that you can use would be to get a non-widescreen standard monitor or install a new video card that has widescreen capability.
Hope that helps,
Take care,
Nov 16, 2008 | Hannspree HANNS-G 19" Widescreen Monitor
Vertical size
LCD monitors auto adjust and use a fixed resolution. It's impossible to reduce the vertical scan. The only what I could think of is to specify a widescreen resolution if the monitor is not widescreen and this may only work if you are connected by DVI cable. Sorry!
Jan 16, 2008 | Sony SDM-X95KB (Black) 19" LCD Monitor
Hannstar AH-191D Monitor Logo
Top Hannstar Computer Monitors Experts
 Russ Hill
Russ Hill
Taidan Johston
Taidan Johston
Are you a Hannstar Computer Monitor Expert? Answer questions, earn points and help others
