Question about Dryers
Kenmore he4 control locked light is on, dryer won't work
  • 3,037 Answers
You can first try unplugging it for 30 minutes to reset the machine. If that doesn't help then you would need a volt/ohm meter to check the control panel assembly(These can be bought at any electrical store such as Radio Shack). The tech. data sheet is located in the very bottom behind the lower front access panel on the unit.
To remove the lower access panel:
You first remove the 3 bottom torx screws on the very front bottom of your washer next to the floor, then Remove the toe panel by lifting slightly and pulling forward.
You can buy a new control Panel from Repair Clinic www.repairclinic.com at no risk as if the part doesn't fix the problem, send it back. Let me know how this turns out.
Benjamin
Posted on Jul 16, 2009
I have the kenmore elite HE4 dryer and the cycles lights went out and are not coming on how do i fix this
Check and see if child lock is engaged first.
Press the end of cycle signal button for 3 seconds
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
If that don't work I would look for reasons why the dryer duct fuse would blow and correct that by removing air restrictions that would cause overheating.
HE dryer notes and service manual
Apr 12, 2011 | Kenmore Elite HE4 Electric Dryer
The Control Locked light is on and nothing will work
Hello
When the control lock light remains on and no buttons on the keypad work then it means that the controls are locked. Press the AUTO DRY button and hold it for 15 seconds to unlock/reset the controls. Please get back to me if you have any other questions.
Kevin
Nov 24, 2010 | Kenmore Elite HE4 Electric Dryer
Control Panel Kenmor Elite HE4
that sounds weird to have all those lights on...
first thing is to try and remove the "lock"light...
push and hold the button, for 5 seconds, below the "lock" light,
that should get the control back to normal operation. then if you still cant get the unit to turn on, try to unplug the dryer for a few minutes.
if you still cant get it to turn back on, call sears "customer service" and complain since your machine should not have failed at this early in its life.
Sep 15, 2009 | Kenmore Elite HE4 Electric Dryer
Control locked
Mine has an "auto dry" button. It says underneath, "Press & hold 3 seconds..." to unlock control. I did it, it worked.
Feb 07, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 electric dryer locked on express dry only......
Shut the breaker off for several hours. Turned it back on.
Nov 30, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer won;t work
Remove the top cover and take a hair-dryer to the PC boards on the back of the main control panel.. (3 screws take the top cover off from the back) Mine has done it a total of 5 times now.. what it needs is all new buttons installed.. or a new control panel if this works..
Feb 22, 2008 | Kenmore 82822 Electric Dryer
The Control Locked Light stays on and nothing else works
Is this like a child lock?? if so holding the appropriate button down for upto 10secs is the fix. is the control locked? it not its just the diode circuit which is faulty and will not effect the operation
Jan 01, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
16 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
