Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
Dark picture! I can not seem to get the picture bright.  DVD, XBOX, Direct TV look dark and gloomy. I have to make sure all light are off in order to see a bright picture. I tried adjusting the presets to " Day Time" still looks dark! Set lamp power to full. Any clue?
  • 668 Answers
The Lamp it self, the Ballast, or the Power Supply that powers the Ballast. Even a combination of the Lamp and Power Supply is a common problem. If you have not replaced the Lamp since you have owned the set I would replace that first. The Lamp has about a 3000 to 5000 hour life span.
Hope this helps,
Skyassoc
Posted on Jul 16, 2009
Why is sony bravia dark screen
If your TV seems to be darker than you think it should be, it is possible that the problem is with the light sensor. The light sensor will automatically adjust the picture brightness based on the ambient light that is in the room, (i.e. if the room is bright the picture will also be bright, if it is dark the picture will also be dark).
To turn this feature off go to Settings > General Setup > Light Sensor.
Feb 27, 2015 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Kdl 52v5100 gets dark
Try whether you have the same problem when using a DVD player. Go to settings of menu, select picture settings, try adjusting the backlight level/brightness/contrast/sharpness/color etc. to your liking. Check whether you get the same problem if you use the same input on another TV.
Aug 06, 2012 | Televison & Video
I have a proview lcd screen and it palys the tv shows in back ground but it's a dark screen like dark blue no picture. Volume and everything working but just no picture. What can i do.
Show a torch light on the screen for a distance, and if you can see the picture, the backlight is not lighting up. Check for its settings on the remote, if you have that option. Check also the settings of brightness/contrast/sharpness/color. If you still have problems, please call in a qualified service technician.
Jul 25, 2012 | Proview PA-37JK1A 37 in. LCD Television
The picture on my tv is completely dark, but the sound is working fine. how can i fix the picture? because it's a fairly new tv
Hello
Keep a close look to the screen, and see whether there is any trace of picture on it. If it is there, you can see pale shadow of it moving. If it is there, be sure that the backlight is not there. Thhere is an inverter board to energise the CCFL lamps used as backlight component. If the inverter board got faulty, the CCFL lamps won't light up, and no brightness will be there with LCD TVs. Check it. OK.
Oct 22, 2011 | RCA L26WD12 26 in. LCD TV
Brand new 47" "Edge Lit" LED, model MV4(Cant
I believe there may be another setting, it has to do with auto contrast which can make the TV seems to have high contrast ratio but sometime it does not work right, espically on the scene with dark sky with stars, someitme it will will reduce the brightness to make black real black and you can loger see the stars in the scene. I forget the name of this setting, it may be in the user manual. Do you see that in TV HD mode in other movies with a lot of dark scenes?
Dec 01, 2010 | Televison & Video
Adjusting darkness
Hi Angel,
Are you really sure , your set has video? How dark is it ? As if really nothing visible? Am, sure you can hear sounds. You can adjust the brightness + button to increase the brightness. But if nothing happens , you have problem with your TV set. The problem might be in the Video section. Please let an expert technician to check it. Please don't do it by yourself, it's risky.
Please send feedback whatever comes up. So we can help you further in the future.
Thanks,
Eriez
May 26, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Xbox 360 picture problem
check vga cables or composite cables
May 24, 2008 | Microsoft Xbox 360 Console
Dark picture on toshiba tv 32af44
Sound like the back light has gone, its what gives the picture brightness. Sounds like a technician job. Sorry........
Apr 10, 2008 | Toshiba 32AF44 32" TV
Screen goes light and dark
sounds like you have bad caps in video area. Will need repair by experience tech.
Sep 07, 2007 | Sony KP-46WT500 46" Rear Projection...
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
335 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
