Scientific atlanta DVR will not turn on, when i plug it in, it says "boot" then goes dark...
  • 304 Answers
Call the Cable co.
Posted on Jul 17, 2009
I have the vc500 hooked up and the software installed. I can see the video on the computer screen but when I press record, the computer video looks like it is scrambled. How do I correct this?
Just a wild pitch here; is the video fine after its been recorded or does that play scrambled as well? Make sure your equipment is tightly plugged in. Other than that, all I can say is maybe your dvr is obsolete or your computer is too slow.
Sep 19, 2014 | Diamond Multimedia ( VC500) Video Capture
Front power indicator blinks, clicking/high pitch sound
  1. This how to is to repair hard drive, software and some firmware issues that can arise on specific cable DVR and DAC and DCT boxes, First instructions are for Scientific Atlanta hardware. Firstly, one should be certain that the cable box has the coax (cable antenna wire) hooked up to the CABLE IN or RF IN on the box itself and be connected to a "hot" outlet - one that you KNOW works. Test it by connecting a TV directly to outlet. If you get a weak signal, the box will too. Digital boxes require a clean SNR. Remove in-line "surge protectors" on the coax. These prevent the signal from being sent by your cable provider to your box.
  2. Scientific Atlanta DVR or High Def boxes:These need to be "booted" or reset when certain errors occur. No audio on certain channels when SAP is NOT set to ON and confounding error codes that one can't seem to get out of. Common yet confounding errors are : No Audio on DVR Playback. No Audio on Certain Various Channels (ruling out SAP which can be enabled through the box, OR the television set itself) there are easy ways to test. If some channels audio is in Spanish when they are normally in English...the obviously you will check SAP first.
  3. Disc errors. On screen error on your TV that says something like..."there are problems with your storage disc.." or upon DVR playback instead of playing your program it loops upon itself and plays nothing.
  4. two different steps to reboot box: Simultaneously press VOL+ VOL- and "INFO" buttons on box itself, not from remote. Box will then display "bOOt" and shut down totally. Do not press ANY buttons or try to power on said box. Wait for the correct time to display on the box. This process can take anytime from 40 seconds to hours, depending on how fast the cable company's servers are responding at that moment and whether or not you have enough of a cable signal to fire up the download process. If you call customer service for your provider if this does not work, most likely a truck roll will be run for a tech to come out to your residence to fix the signal issue.
  5. When the correct time display is on the Scientific Atlanta box, THEN power on box and problems should be solved. An alternate way to reboot box is to simply unplug unit from power supply and replugging it in. Simply powering it on and off with the POWER ON button will not solve anything.
  6. On a Motorola box and/or DVR, the easy VOL+ VOL- and INFO will not work to reboot. Remove AC power plug from wall socket and wait 30 seconds to a minute while box is powered ON. Plug back in to wall socket.Box will "do it's own thing" and power itself on on it's own after the cycle has been successful (30 - 60 seconds) and the box should power itself back to the ON without you doing anything. Time will not display on Motorola"General Instrument boxes unless you set it up to do so in the settings mode.
  7. Common IControl/On Demand errors:
  8. MOTOROLA BOX Error 225 : A billing lock to prevent you from ordering pay per views. If your account is past due, or if you have an order to move to a new address in the service provider's "system", this is a preventive measure to keep customers from loading up tons of expensive pay per views and skipping out. Your cable company cannot over-ride this error. If you are not in above situations, your provider can "up" the limit on the box and clear it so you can order PPV through your remote control.
  9. SCIENTIFIC ATLANTA: for above mentioned error code, your SA box will display not a code but a prompt to contact your provider by telephone. Same issue.
  10. MOTOROLA BOX ERRORS 204...203.. 207..these may be easily solved by simply reseating the coax and then rebooting box.
  11. SCIENTIFIC ATLANTA ERRORS 2207: reboot box. This is a general code meaning the box has lost contact with the server. All of your iControl /On Demand orders come through your local cable head-end's servers. If and when it gets overloaded and times out, error 2207/207 will happen. Most of the time this is temporary. Reboot box, try again in 15-20 minutes.
  12. DVR BOX not displaying/recording/playing items:
  13. Reboot. Good chance of fixing.
  14. If your TV displays "One Moment, Please. Your Channel Should Be Available Shortly..." this is a SIGNAL issue. Reseat the line running from wall to the CABLE/RF IN on the box and at the outlet at wall. If no joy, call cable operator.
Nov 18, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Top and bottom of the screen are cut off
That set has an aspect ratio of 4:3. The problem is that what you are sending to it is 16:9 So you are sending an hd signal to a non HD television. The tuner is NTSC which is not HD. Theres not much that you can do about this.
Jan 17, 2014 | RCA F27650 27" TV
HDMI cable hooked up, now CLOSED CAPTIONING is stuck on!
It has got to be the box. I would try to contact Scientific Atlanta if any way possible. The TV doesn't choose what inputs it shows CC.In other words, it would show it on all Inputs if it was the TV. Good luck and Thanks
Oct 30, 2009 | Toshiba 32AV502R LCD TV
I have an Inovage Jumbo Universal remote that I need to program and believe my wife has tossed the manual. I have a Scientific Atlanta DVR and a Sony TV (just changed tvs as my RCA died; I also added the...
All the jumbos are basically the same. For your RCA TV, I show 000,003,004,005,006,007,019,096,098,099,100,101,102,103,129,179, 181,188,190,196,202,203,215, or 233
For a Scientific Atlanta VCR, I show 006,036, 037, or 038. These codes might work on your DVR as well.
Jul 01, 2017 | Televison & Video
Help!
Unplug the unit> Remove> Take out to back yard> Smash repeatedly with a sledge hammer of at least 2Lbs> Mail the resulting material to cable company preferably next-day.
Apr 24, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Bose Cinemate home theatre
The Bose codes for Comcast remotes for both the Cisco (labeled Xfinity) and Scientific Atlanta (labeled Comcast) DVR remotes are 31229 and 31933. 31933 worked with my Bose CineMate Series II
Jan 09, 2008 | Bose Cinemate Digital Home Theater System...
Off Air?
The Scientific Atlanta box was a cable box and recieved CATV signals. The Direct TV box is satellite only. You might check if it has a built in ATSC tuner for off air digital signals. Direct TV in most locations offers the major networks in HD format.
Jan 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
301 people viewed this question
Top Televison & Video Experts
