Question about Singer Featherweight 132Q Mechanical Sewing Machine
It makes a rattling sound when I sew. It has been
My Singer 221 makes a rattling sound when I sew. It has been cleaned and oiled, and the gears have been lubricated with the recommended motor lubricant. Is this noise normal?
  • teaquilt Jul 16, 2009
    It's an older one with the metal gears. It sews a wonderful stitch, but that noise is bugging me. I was hoping not to have to take it in for repair because I want to use it this weekend.
    Sniper:
  • 52 Answers
If its an older singer featherweight it should sound pretty quiet but if its a newer 221 it has plastic or nylon gears and they can make a "barking" sound
Posted on Jul 16, 2009
  • bbragg77 Jul 16, 2009
    check the hook and make sure thread hasnt caught around it
My Singer stylist 513 sewing machine makes a knocking noise from the top. I have cleaned an oiled it. When I turn the wheel manually, It appears that something is tight and then jumps.
Take out your needle and turn it. Does it turn any easier than when it is in? If this takes place you need to have it serviced to have it adjusted and/or gears possibly replaced. There are other possibilities but the adjusting and gears from underneath are most likely.
Nov 06, 2016 | Singer Sewing Machines
Will not zigzag or decorative stitches. New to these newer plastic style machines Always used older steel machines. This was given to me my by my sister who used it very little. Could cam be broken?
Hmm, I'm wondering if it has been cleaned and oiled recently. Older mechanicals require frequent TLC. Consult your owner's manual for cleaning and maintenance instructions:
Is your sewing machine mechanical (ie, not computerized)??? CAUTION--if your machine is computerized, do NOT proceed with the following suggestions.
If it is mechanical, have you cleaned and oiled your machine recently? Most mechanical sewing machine failures are because they have not been adequately and routinely oiled, the old oil has solidified and frozen the mechanics. I recommend Bernina oil or liquid Tri-Flow Synthetic Lube (or similar good quality sewing machine oil) for mechanical machines--do NOT use 3-in-1, cooking oil, WD-40, or the sewing machine oil from your grandmother's sewing basket. (I am not associated with any Bernina dealer.)
If it is in fact frozen, pick up a bottle of liquid Tri-Flow Synthetic Oil at the hardware store. Oil one or two drops in every oil hole (see your manual) and also every place where metal rubs on metal. But DO NOT oil any plastic gears, rubber, or belts. If it is still stiff or frozen, direct a hot handheld hair dryer into the top and bottom mechanism of your machine. See if that loosens it up. You may have to repeat.
Once your machine is working again, place a drop or two of good sewing machine oil as directed above. Be sure to use a small brush to clean the lint and dirt out of your machine, especially around the feed dogs and bobbin area. (Caution: Compressed air will sometimes force the dirt and lint into areas that cannot be cleaned.) And continue to use good quality sewing machine oil to keep it running. Recommendation: every time you change a bobbin, after 8 hours of sewing, or every six months if it is not in regular use.
Dec 30, 2015 | Singer 6038 Mechanical Sewing Machine
How do I set the bobbin on the singer featherweight so it does not hit he upper plate
Go to the Singer Sewing Machine Site, select Support, and there is an option to download your user's manual free. On page 7, it shows you how to insert both the bobbin and bobbin case.
I have seen many of these cases, and here is how they work. You'll notice a lever on the front of the case. When that lever is in, you can't remove the bobbin. When you need to insert the case, you have to lift the lever, making sure that the protrusion in the case is on top.
Feb 17, 2015 | Singer Featherweight 221 Bobbin Case,...
Bobbin thread bunching on singer sewing machine...have changed needle and tensions! Help
Try a ball point 11/70 or stretch 11/70 needle. Also rethread the entire machine. Make sure the needle is inserted correctly in the sewing machine. I had this same thing happen to me recently and I found I had the needle backwards.
Aug 06, 2014 | Singer Featherweight 221 Bobbin Case,...
Does the Singer 221k7 need to be lubricated? If so, where?
contact singer customer service and ask them if your machine
needs to be oiled
Mar 27, 2013 | Sewing Machines
HI! I am looking for a free wonsload of the Service Manual for Singer 221. can anyone help? thank you
Go to www.singerco.com and under customer support, instruction manual, enter 221 and download a free one.
Feb 27, 2011 | Singer Featherweight 140Q
Have singer sewing machine that the tension on the bobbin isn't very good no matter what i turn the tension to. the model # is 221K1 or 221-1 it seems like it is also needing oiled down there but don't...
99% of the time its not the bobbin tension its the tension on the upper thread that is off. Try rethreading the machine and then adjuat the upper tension slowly if needed. The bobbin area does need to be cleaned quite often usually every 8 to 10 hours of sewing and its simple to do. Remove the bobbin and look closley at the bobbin casing there are two latches holding it to your machine, one on either side you push them gently to the side and the case will come out, clean and oil entire area and replace the case and push the latches back into place and then replace bobbin in machine aalways use scrap material for a few minutes to make sure everything is good to go and that no oil gets on you project. any machine oil is ok to use its not necessary to use sewing machine oil and a small bottle will last for a long time.
Oct 28, 2010 | Singer Sewing Machines
Singer sewing michine model 3116, when sewing makes a
How long has it been since you oiled it? That may be all you need to do but be sure to use sewing machine oil
Dec 17, 2009 | Singer 3116 Simple
Wheel turns very slowly does not speed up when
Try oiling all the moving parts with WD40, old oil on the machine may have congealed, make sure there is no thread stuck in the raceway.
Oct 19, 2009 | Singer Sewing Machines
What kind of bobbin singer 301 machine use
The Singer 301 uses the same bobbin as the Singer 221 (also known as a Featherweight). Not surprisingly it's called a Class 221/301 bobbin and is Singer part number 45785. If you don't have a Singer dealer or large sewing machine repair shop in your area, I would suggest purchasing from a reputable online seller such as Vintage Sewing or Sewing Machine 221 Sale. Below is a picture of what both the older and newer style of this bobbin looks like. 11da97d.jpg
Mar 23, 2009 | Sewing Machines
Singer Featherweight 132Q Mechanical Sewing Machine Logo
559 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
