Question about Frigidaire 19.7 cu. ft. Chest Freezer GLFC2027F
My frigidaire glfc2027fwo is getting very hot above the compressor area. I believe this would be the condenser location. however i do not see how to access it for cleaning.
  • masd1964 Jul 16, 2009
    I am also getting corrosion on copper tubing and a strong oder. is there any way to clean the condenser?
    the smell is comming from the compressor area.
    We have a small catering service. We keep everything clean. I have removed everything from the freezer and cleaned under and behind it.
    this has been going on for 2 weeks now. could it be the condenser burning the insulation ?
Here is the link to the original owners manual:
http://manuals.frigidaire.com/prodinfo_pdf/StCloud/297079200en.pdf
I looked over the manual and here is what I have found:
Freezer external surface
temperature is warm.
* The external freezer walls can be
as much as 30ºF warmer than room
temperature.
* This is normal while the compressor works to transfer
heat from inside the freezer cabinet.
Page #7 is all about the care and cleaning of your Frigidaire
Posted on Jul 16, 2009
  • Anonymous Jul 16, 2009
    Is the odor coming from the inside or outside?
    I would open it up and check...look for some screws or bolts that are removable...flip it over if you have to...if that odor is "food" related then you may need to get to it so you can clean it out (maybe some meat juice dripped down into the bottom) If it smells like burning wire then I would unplug it and not use it untill you can see the compressor area and verify everything is 100%
How do i get my condenser fan to stop running. it is cooling fine but won't shut off unless i shut it off.
Are you sure its the condenser fan? The fan is attached to the compressor power and wont run unless the compressor is running. On the other hand the fans inside the cooler will run 24/7 and are designed for continuous duty. If someone has worked on the compressor wiring you may have to re establish the wiring following the wiring diagram. I have seen condenser fans wired in hot areas to run continuously to attempt to cool down a hot compressor or compensate for a worn out or damaged condenser that doesn't get rid of the heat from the system. If that is the case a new condensing unit is probably in your future. Hope this helps good luck.
Oct 09, 2014 | True GDM-47 Refrigerator Merchandiser -...
Hot side panels
Hello Robert - From what you have described, it seems like you may be referring to the perimeter hot tube. It is normal to be warm to the touch; however, since it may feel hot to you, I would suggest verifying that you have the proper clearances around the refrigerator. You can refer to your owner's guide for those specifications. If you do not have an owner's guide, you can download one at the manufacturer site. If the clearance is fine, you may need to clean the condenser coils. As part of routine maintenance, you can remove the toe grille (located at the foot of your refrigerator) by unsnapping the sides and lifting outward towards you. Now, using an extended vacuum attachement and condenser cleaning brush, remove dust buildup from condenser coils on left side underneath refrigerator. Cleaning condenser coils typically resolves this issue. But, if clearance is fine and the condenser coils are free from dust and you are still feeling too much exterior heat, you may need to check with a local service tech to determine what else could be causing this issue.
Apr 24, 2013 | Frigidaire 13 cu. ft. / 368 liter Chest...
Upright Freezer won't Cool
Hi - Typically freezers are not recommended to be located outside because if the garage temperature is above 100 degrees, it will have difficulties performing optimally due to un-circulating air. Some manufacturers have garage kit design to help with this issue. It is design to solely be used during the winter to provide heat to the coils which trigger the compressor to come on. During the summer months, generally it is not needed.
When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Contact a professional to move forward accurately from this point.
Oct 14, 2012 | Frigidaire GLFH17F8HB Upright Freezers
Sub zero freezer - 501 f
It is likely the condenser fan is not functioning. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Jun 19, 2012 | Sub-Zero Freezers
Freezer is not freezing some items like it should. The compressor is extremely hot and cannot be touched.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 24, 2011 | Frigidaire Freezers
This is a second hand freezer purchase. When starting it for the first time, it cooled rather quickly inside but the sides and top became very hot to touch and we unplugged it. Is this a dangerous problem?...
Usually the frame getting hot is a sign that either the condenser grill is dirty or blocked or not getting enough air flow around it; or the condenser fan is not working or maybe even the compressor being low on freon.
I would suggest you start with a thorough cleaning, then check the fan and make sure it is working.
Since you said it cooled down quickly, I wouldn't think it was the compressor freon level. More likely dirty condenser grill or where you put it. I have might on 4" x 4" to get it off the ground for better air flow and ease of cleaning. It must work because I have had it since 1983 and never had to do more than clean the grill on it.
Jul 01, 2011 | Frigidaire Freezers
Unit makes ice,full evaporator,is very slow,maybe 45 mins. from harvest to harvest. Why so slow?
Possible causes are many
Things to check
  • If air cooled, is the condenser coil clean and is the condenser fan running when in ice production ? Is the area extremely hot where the ice machine is located? If water cooled, is there adequate water pressure and is the water regulating valve set properly?
  • When the system switch is in the off position is there any water running ( if so the inlet water valve may be stuck open)
  • When in ice production, is the small tube that feeds from the hot gas solenoid hot? This tube comes from a valve at the back of the unit and feeds over the compressor and into a tee near the insulated Tx valve. This line should be hot during harvest and cool shortly after harvest.
  • Has the float switch assembly been cleaned. this is a cylindrical unit beside the water pump,It can get plugged with minerals and not initiate harvest
  • The system may have a refrigerant charge problem (short) or the compressor may be weak, at which point diagnosis would need to be done by a refrigeration tech
Hope this helps
Oct 29, 2010 | Hoshizaki Freezer Commercial Ice Machines...
The temperature regulation is very hot and the compressor doesnt stop, is that normal? the freezer was shu down for more than 24h
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 10, 2010 | Frigidaire 15.0 cu. ft. / 425 liter Chest...
Cooling but not freezing
Clean and inspect the coils around the compressor area. Check for a functioning condenser fan and feel the compressor if it is very hot to the touch the relay is probably fried.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 17, 2010 | Frigidaire Freezers
The fridge/freezer is making buzzing noises that go on for 10/15 seconds every 5 minutes or so. Both fridge and freezer have heated up to 49 and 26 degrees through the night. Help!
ur compressor is trying to start but the safety is turning it off may have a bad compressor but try this first might get it working again -(safety click sound) disconnects power when compressor gets to hot or is drawing to many amps--stuck--comp gets hot unplug unit and clean with a vacuum carefully under where comp and fan are this is the condenser area after cleaning or 1 hr plug in and check for start and that condenser fan is working may be reason for overheating-if still not working compressor needs service
Nov 04, 2009 | Maytag Freezers
Frigidaire 19.7 cu. ft. Chest Freezer GLFC2027F Logo
80 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
