My machine doesnot fill water,as water start's and fill my drum it start leaking from somewhere, we checked water leaks from water pump. Last year we replace water pump. ya we change drain hose also.that is ok.
    President:
  • 1,136 Answers
Hi, If the leaks is small, check the hose that attaches to the fill/pressure cup on the side of the outer tub. This hose is also connected to the water level switch. If you wil get me the make and model 3, I can look this up so that I can assist you further.
Thanks,
Vic
Posted on Jul 16, 2009
    Sergeant:
    Novelist:
  • 197 Answers
The valve to the powder drawer is jammed. When you try to start the machine it trys to open and he water will try to pass through the valve. The water is at a constant pressure when the machine is off, but when you turn it on, it increases the presure and the water leaks. To the back of the maching, look at the blue hose, to the back of the washer, that should be sound, take the top off the machhing, two small screws at the back, follow the black hose from the cold inlet to the valve and I think you will find that is split/perished. I hope this helps, but if not let me know and I'll check o/l to find the fault for you.
I have a Kenmore Elite quiet pak 4 he3t that is leaking. ?
Firstly unplug it!! Then take top off see if its coming from the pipe feeds drawer.then pipe from drawer to drum.first part of any program is to pump out anything left over then it starts to fill.check pump .its hard to say from not seeing it could come from anywhere.just unplug then start looking with a torch
May 02, 2016 | Kenmore Washing Machines
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
It started leaking when filling with water...why?
I've had to replace the internal hose three times where the water connections are. It is a "Y" hose, that is not sturdy, and a defective design. I've had this washer for three years, and this keeps happening. If you look carfuilly, you'll find a hole at the "Y" junction.
Feb 22, 2010 | Malber P21 Front Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Older model washer, water coming out under the washer
hose could be leaking going to your pump there are two attached to it, also the pump has a seal where it connects to the motor could be leaking there, and there is a tub seal. but it does sound like a hose came loose
Feb 10, 2010 | Washing Machines
Machine is leaking water from somewhere?
there is a seal between the drum and transmission,more than likely thats where its leaking. also check your fill hoses and valve
Jan 09, 2010 | Kenmore 22422 Top Load Washer
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Washer leaking when filling up tub
Unlikely to be pump, sounds more like hose leaking, or drum seal.
Depending upon severity of leak, place a sheet of newspaper under front of m/c, pushing it as far back as you can. switch m/c on for a few secs, then switch off, remove paper and you should be able to judge where leak is.
Tilt m/c back and have a look underneath.
At 12 years old, if it looks major, I think I would replace m/c.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Maytag Dependable Care LAT9206
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
