One wire will for high beam
one wire will be for low beam
the last wire will be ground wire
as fog light have only one beam you can use the low beam wire and parallel wire it to the fog lights
that way you have the head lights still and the fog lights as accessories correctly wired according to regulations
how to do it simply-- find the low beam power wire ( light switch on low beam and power at the light bulb check ed with a multi meter set on volts
solder , piggy back, or double plug in a connection into that wire and run one wire to the left fog light and one to the right fog light connect each fog light to an individual ground wire and connect those wires back to the ground wire for the main lights
Now having done that simple addition to the lighting system another problem has come up
The wiring will now be too light to carry fog light current and or the light switch will burn out
To over come this problem, the circuit needs a relay
fit a relay on the bike and now run the low beam wire to a terminal of the relay
run the other terminal wire to ground
this enables the relay to operate when the low beam is switched on but at this will not switch on the lights yet
now you have to run a heavy gauge wire (fused at the battery) to one of the power terminals of the relay and from the other power terminal to the connection for the fog and low beam lights
Now it all works switch on the high beam and no for lights
change to low beam and the fog lights come on as well
All nice and legal
Of course if you don't care about being legal just buy a 30 amp toggle switch and run a fused wire directly to the switch from the battery to the lights and then to ground from the lights
You will know that the generator / alternator for the bike will not be able to run the fog lights with or without the main lights so what will you have achieved
SOURCE: headlight wiring diagram 95 honda accord lx
Red/white is left high beam and red/yellow is left low beam. Red/orange is right high beam and red/green is right low beam.
SOURCE: No Hi Beam on 93 Camry
The headlamp circuit is rather simple. From the 15 amp RH headlamp fuse, there is a red w/yellow trace that goes to the RH high beam. Out of the 15 amp LH headlamp fuse, the wire going to the LH Hi beam is solid red. Both of these wires should have power when the headlamp relay is energized. The wires from the Hi Beam bulbs going back to the switch should both be red w/black trace. The wire going from the headlamp relay to power the 2 15 amp fuses is white. The headlamp switch applies a ground to illuminate either the Lo Beams or the Hi Beams.
SOURCE: hhr fog lights
yes it is you will probably have to have the bcm programmed for the foglight option if your gonna install like factory is
SOURCE: need wiring shematic for fog lights 2005 toyota corolla
im pretty sure these cars were already prewired for fog lights .there should be some plugs behind the bumper to fit them.if not get back i will explain how to wire them up.best of luck.
SOURCE: I need the wiring diagram
This is the diagram for the fog lamps ( headlamp is a different cell ).
If you are trying to add them to the existing wiring, do not expect the headlamp switch to cab fuse panel wiring to be there ( that is usually what is missing when you can find the fog lamp connectors under the front of the truck ).
File Save as so you can magnify it with the JPEG viewer you use.
Close up of switch
Testimonial: "Thanks for the diagram, I'll have a pro install the needed wiring."
