SOURCE: We replaced the radio in our '98 Cadillac and no door chimes
Did you replace it with a factory radio or an after market one?
If you did the after market one,it's not wired correctly.
SOURCE: 1998 Cadillac Deville low fuel
Hi, yes the fuel level sensor is the likely culprit. Rather than disconnecting the chime, you may want to replace the sending unit. The reason is it is likely to get worse over time, and eventually the sender will fail to read the proper fuel level. You can get a new sending unit for about $100. Unfortunately, the labor is a bit expensive as the tank must be removed to replace the sender, unless your model allows access through the trunk. My manual does not say whether your car provides access or not--it only says to check for access by removing the spare tire. Look there to see if there is a door to the bottom of the car. If there is, the procedure is much easier. Basically, you just disconnect everything from the fuel pump assembly, turn the lock ring (there is a special tool, but I use a couple of screwdrivers for this) to unseal the pump from the tank, and lift out the pump with the sending unit. Replace the sender on the pump and reinstall. Do this when the tank is less than 3/4 full. Please let me know if you have questions, and thanks for using Fixya.
SOURCE: My 06 gmc sierra's oil
replace oil sending unit located on driverside rear of engine back of intake this should cure the reading errors
SOURCE: 1997 cadillac eldorado.. stop engine
See if oil pressure sensor is leaking oil, if it is, replace it. It may be LYING or maybe NOT?
