I want to replace the pcb main assembly in my lg washer. the only thing that went out but one problem. how the heck do i take the top off. ? Can anyone help
  • 1,543 Answers
On the back of the washer, take off the bottom screw of the plastic parts on the back edge of the washers top. Now, standing in front of the washer, use the palms of your hands to sharply push back on the L and R edges of the top. It should slide back about 2 inches. Now, lift the top off.
Posted on Jul 16, 2009
How does a PCB main assembly look like on a LG washing machine
pcb board main is the one thats accessed though the back of the washer behind the panel, the unit is usually at the bottom left side and has loads of wire and plus on it, it controls the motors and the heating element when told by the cyle board, it has switch-relays that turn things on at the times set for the setting you you to wash your items.
May 31, 2017 | LG Washing Machines
I have an LG RU-42PX11 plasma tv. A couple weeks ago we heard a pop and the picture went blank. I can still change channels via cable box and I have sound but no picture.
6871QCH034A PCB ASSEMBLY,DISPLAY CTRL ASSY 42V6 NEW MCM(1222) LVDS
202 6871QDH066A PCB ASSEMBLY,DISPLAY YDRV ASSY 42V6 YDRV TOP ASSY
203 6871QDH067A PCB ASSEMBLY,DISPLAY YDRV ASSY 42V6 YDRV BTM ASSY
204 6871QLH034A PCB ASSEMBLY,DISPLAY XRLT ASSY 42V6_XL(4LAYER)
205 6871QRH037A PCB ASSEMBLY,DISPLAY XRRT ASSY 42V6_XR(4LAYER)
206 6871QYH029A PCB ASSEMBLY,DISPLAY YSUS ASSY 42V6
207 6871QZH033A PCB ASSEMBLY,DISPLAY ZSUS ASSY 42V6
These are the part numbers for all the boards that deal with the display. Im leaning towards the sustains as well and you need to do both at the same time cause if one is bad and you replace just one, a bad one can fry the new one.
Jan 20, 2017 | LG Televison & Video
Why doesn't the start button work?
1. Check to see that the washer is plugged in.
2. Check to see that there is no tripped breaker for the washing machine circuit.
If the washing machine is getting 110V at the plug, then you could have:
1. Defective Filter Assembly or
2. Defective Main PCB
3. Display PCB
Aug 08, 2015 | LG Washing Machines
LG Top Loader will not turn on
did you check power connection?...if power is there we have to check main PCB Power piuse,,,,
Apr 15, 2014 | LG WFT1071TP Top Load Washer
DE error code on LG washing machine
Beyond that could just be the door latch itself.
Nov 23, 2013 | LG WM-2277HW Front Load Washer
LED Display
You can find the display PCB assembly at any LG authorized parts distributor and it is part number EBR36858901. It can be replaced easily by removing the top panel and the console. Unplug the dryer before servicing.
Remove the screws securing the top panel to the rear of the washer and slide the panel to the rear of the dryer. Lift the panel off and remove it from the dryer.
Remove the screws mounting the console to the dryer cabinet and disconnect the wires from the console.
Pull the console upward and then forward to remove it from the dryer. Remove the screws securing the display PCB assembly to the console; mount the new one and secure it into position.
Reinstall the console to the cabinet in reverse of the removal steps and connect the wire harnesses. Slide the top panel back into position and secure it to the rear of the washer.
Apr 12, 2010 | LG DLE5955 Dryer
Model DD603 top drawer has no power and is difficult to open/shut....Help!!
No power to top drawer,.... sounds like the main pcb is shot.... and happened when the washer was in use, so the lid assembly is clamped down, you can still open it by pulling but has alot of resistance. easy to replace the PCB, but dear to buy it!...
Nov 19, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
LG Washer won't power up
LE Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective.
Aug 26, 2009 | LG WM2277H Front Load Washer
Error message on wpgt9350c0pl washing machine
HI. the Main Pwb/pcb assembly(board) must be replaced in this case. there is a chip set failure that has occurred. The main board is inoperable at this time.
Aug 06, 2009 | GE WPGT9360EPL Top Load Washer
Washing Machines Logo
265 people viewed this question
Top Washing Machines Experts
