Question about Whirlpool GU2400XTP Built-in Dishwasher
Water is not reaching top spray arm.same problem about a year ago.took apart unit on bottom inside of dishwasher and removed build up;said it was because we have hard water.how can i fix it as it is of course out of warranty(17 mos old).
  • 234 Answers
You're going to have to take the unit apart and clean the build-up again. Since you have hard water, it's recommeded that you use tablets instead of gel or liquid detergent. If you get a water softener, you'll have to use liquid. Good luck and sorry to hear about the hard water. I have the same thing here and it's no fun. Good luck :)
Posted on Jul 16, 2009
  • Ned Halaweh
    Ned Halaweh Jul 16, 2009
    Problem Solver:
Is there a grease trap in the dishwasher .the water wont each the spay arms et all.i took it apart ,and underneat the dishwasher its like there is a big block of grease but i cant find how it open it,can you help me plz
Posted on Jul 21, 2009
You have to take the unit apart inside at the bottom beneath the sprayer. Something is blocking the water inlet flow/inlet valve not allowing the dishwasher to fill with enough water to function properly. Mine had a handfull of food and debris. This is a simple job using only a screwdriver. Should take only 15 minutes. Wife is happy again
Posted on Jul 19, 2009
Why is my Bosch dishwasher not washing on top rack
Maybe the pump isn't working to its full compasity and not pushing water to higher elevation.
Aug 31, 2014 | Bosch Dishwashers
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher not cleaning
Remove the panel at the base of unit below door you should find the tech sheet which will tell you how to place unit into diagnostic, on the spray arms make sure the small holes are clean below the lower spray arm is a screen make sure it is clean not covered or cake with calcium build up if it clogged water cannot pass thru to enter the wash pump you can also remove the screws to take the upper halve apart to inspect the wash pump for any obstruction it is possible you could have a bad motor control or both you didn't mention after the unit fills do you hear the wash pump hum or click
Feb 07, 2014 | KitchenAid 24 in. KUDK02CRBS Stainless...
Bosch shy66c02uc
JESUS ALMIGHTY
Dec 18, 2013 | Dishwashers
Whirlpool DU1301XTV dishwasher - the top rack started cleaning woefully a few months ago. The bottom seems OK. I checked wash arm action by starting the washer and opening the door several times. The...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Nov 04, 2010 | Whirlpool DU1301XTV Builtin Dishwasher
Water not pumping out spray arms.
clog in the arm. It should spin due to water flow.
Remove the arm. Usually a tow part arm (top and bottom). Or a central screw with cover plate.
Look for a clog and remove.
If a central arm in the middle of the machine the clog can be in the pipe supplying the water. Again take apart and look for a clog.
They are not belt or gear driven. Simple water driven parts only. If the water is flowing and not leaking under the machine you should be OK with a simple clog somewhere.
Mar 07, 2010 | Kenmore 24 in. 17283 Built-in Dishwasher
Bottom rack cleans fine, top rack doesn't clean at all - can I take apart the top spray arm?
yes, the spray arm can be removed and cleaned out.
Also, clean the 3rd (very top spray area) located attached to the top of the dishwasher. You want to make sure this small (1 inch size) piece can spin freely, so water can rinse the upper rack items.
Feb 01, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
Mar 18, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Bottom rotating arm doesnt spray water but top arm does
i have a similar problem. water is not reaching the bottom spray arm. there. i have an underwater case for my digital camera, so i'm going to put a torch or 2 in some waterproof bags and remove the bottom spray arm and run the dishwasher to see if there's water coming out of the bottom pipe, if not, i need to try and see if there's a blockage in the system, or a dodgy valve, could be that the soldering's or the control panel's buggered.
Nov 24, 2008 | Siemens 24 in. SE25T250 Free-Standing...
Small plastic top and mid spray arm do not turn, bottom does
decrete, you want to get down to the chopper and screen. If the screen is plugged up with gunk there won't be enough pressure to reach the top spray arms. Check out the posted pics. Remove the lower spray arm. Rotate the rear feed arm to the right until it unsnaps from the tube going up the back. See the 4 torq screws holding the filter on. Remove them. Lift the filter up. Now you will see the chopper inlet cover. 1 torq screw holding it in. Lift it up and there's the chopper and screen. Catriver..post back
Apr 09, 2007 | Whirlpool GU2400XTPS Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
270 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
