I lost the combination to my safe and need to get into it due to a family emergency.
    President:
  • 1,129 Answers
Drill out the in the area in front of where the latching mechanism is, when drilling the hole use plenty of cutting oil and whatever you do go relatively slow with the drill rpm or you will burn up the drill bit you may want to purchase more than one drill bit for this job and when drilling use alot of pressure and less rotation speed the drill will cut better and last longer, don't go too slow however the last thing you want is to snap off the drill bit you may need to drill a number of holes in the area of the latch to compromise the latching mechanism enough to start the door to housing seam moving with a pry bar, use a dremel tool to enlarge the space between the door and the safe outer housing to accomidate the prybar tip, make the gap with the dremel large enough to easily fit the pry bar in far enough to get some leverage because drilling the latch alone wil not open the safeonce it is open enough take some large screwdrivers and wedge them in around the smaller spaces (have an assistant hold pressure to hold the door open) to expose whats left of the internal latch if you can get the dremel cutt-off blade in ther use it on the latch if not purchase a small hack saw that allows the blade to extend out and use it to get in and cut latching mechanism.
good luck i wish you the best
Posted on Jul 16, 2009
Sentry. How can I reset combination?
You can't. You bought a paperweight ?? The whole idea of having a safe is that it is secure. If there was some magical way to reset the combination you could do that with all the safes that have 10 grand in cash and the family he wells in them.
The only way is to take it to a locksmith and they will drill the door, open it and fit a new one. You can imagine the cost of that.
Get your money back if you can't get the combination from the seller. My bet is that they sold it to you because I gave them this information a couple of weeks ago.
Nov 18, 2015 | Home Security
V332 combination insruction
Try this:
http://www.1stvision.com/cameras/IDS/dataman/uEye_User_Manual.pdf
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Jan 22, 2013 | Home Security
How to open sentry safe sfw123cs
Anon, Contact a local locksmith, most of them are skilled in opening small safes when code or key lost.
Check the attached links,instruction and guides on how to open your safe. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
SFW123CS Combination Fire Safe
http://content.etilize.com/User-Manual/1027349209.pdf
How to open sentry safe sfw123cs Sentry FIRE SAFE Combination Safe DS3431...
Emergency Locksmith Services Aim Lock Safe
Jan 21, 2012 | Sentry FIRE-SAFE Combination Safe DS3431,...
What is the code in enterfactory
Hi.
Hi. There is no factory fixed code. Thieves would be the first to benefit from such feature! The factory code is uniquely associated to the safe serial number and it is stored in Sentry protected database. When original code is lost the only way to unlock the safe is bay following Sentry's procedure.
Contact Sentry immediately. They will first try an emergency unlock code, and then they will give you instructions in case the safe must be serviced. Here the contact: Call or Email Us
Here general instructions about what to do when combination does not work. Instructions are addressing lost combination.The procedure is the same in all cases when combination does not work (malfunctions, lost combination etc.) . Please contact sentry and follow procedure to get the safe open.
Regards.
Ginko
Oct 05, 2011 | Sentry Fireproof Safe
You can contact the manufacturer with the model #, serial #, and proof of purchase to get combo. If the combo had been changed, a locksmith will have to drill it to open it.
Jul 16, 2009 | Office Equipment & Supplies
Lost combination and need to get into it for family emergency.
You have to contact sentrysafes.com for directions on obtaining lost codes
Jul 16, 2009 | Sentry Fireproof Safe
I forgot combo'
If you have lost the combination, and the safe is closed, you will need to contact Sentry to get an emergencey access code. Sentry charges $12 to release emergency access code.
Here is the unloack page.
If the safe is open, then you can also try istructions here:Lost combination or keys WARNING
Jun 26, 2009 | Sentry Fireproof Safe
Lost combo sentry v530
See also:
Apr 27, 2009 | Sentry Fireproof Safe
Can't open combo/key sentry safe.
See also:
Apr 18, 2009 | Sentry Fireproof Safe
k24674
