Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
Bissell ProHeat, Brush won't turn, belt fine.
Bissell ProHeat, Brush won't turn but belt is not broken, We can barely get it to turn by hand.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dh
Posted on Sep 30, 2010
Bissell powerforce brush won't turn when powered
Hey, you may want to have check if the brush turns by hand without the belt in place. If the brush doesn't turn manually, you'll need to replace the brush.
Here's a quick link to the BISSELL website to assist you.
http://www.bissell.com/default.aspx?cid=ccsocial
Feb 12, 2013 | Vacuums
Brush is not turning and water is not coming out when lever is squeezed
You may have a broken brush belt they break far too easily. Turn it over and look around the sides of the brush for a broken rubber belt.
Dec 08, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
The unit does not put any watter on the carpet and when I push the triger the red spinner does not move. The tank is full of hot watter
This sounds like your pump brush belt is broken in your Bissell. The belt controls the pump in the machine, as well as the brushes. This would be explain why the solution is not spraying, as well as why the red spinner on the top of the machine is also not spinning.
Here's an extremely helpful video that you can watch on how to replace the belt on your Bissell ProHeat Carpet Cleaner.
If you open up the door and find that your belt is not broken, please just reply using the Clarification Request form here on the Fixya website, and I'll be more then happy to do some advanced diagnosing with you to figure out what the problem is.
How To Replace the Bissell ProHeat 2X Carpet Cleaner Belt:
http://www.bissell.com/VideoRating.aspx?id=1555
If this information was helpful to you, help other Fixya users with the same problem find this video by clicking the very helpful four thumbs up icons in the top right hand corner of the repair.
Thank you very much,
Chris J.
GoVacuum.com
Apr 12, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell proheat turbo, the brush will not rotate.
Have you check for obstructions on the brush, especially towards both ends of the brush? Check for things like string, tinsel, etc. that can stop the brush from rotating. Check to see if you can turn the brush using your hand but don't force it if it is jammed. If its free of debris and turns with your hand then you have a more severe problem. I don't believe this unit has a belt but hopefully my prior tips will help. Good luck!
Mar 14, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
Anyone know why my Bissell Proheat 2X Turbo Model 9300's brushes won't turn anymore
If the Brushes don't rotate, & you have two brushes; 1). Turn unit on side. ( Make sure unit is up-pluged) 2). Rotate the front brush roller, if the second roller moves at same time, 3). Locate a small ribbed belt that goes from the further back roller, to a small ribbed pully. (Gates belt #177-3m5) ( on side under a clear cover) The belt may not be broken, but may have carpet fuzz / lint covering the belt ribs, causing the belt to slip. If that belt is OK and you find that the small pully doesn't turn the belt/rollers, the problem is with a small internal direct drive motor, that drives the brush rollers. At this point return the unit, as Bissell has a design defect & is using cheap parts.
Nov 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 Brush Problem
is the drive belt slipping? are the brush end bearings running free try turning by hand to see if they have free movement .switch off first.good luck farr64
Apr 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Cannot figure out how to install brush belt on a bissell proheat
heatman101
twywt
Jan 16, 2009 | Bissell 8910 ProHeat Clear View Upright...
My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
Brush belt is very weak.
Brush Belt broken or disconnected. Very weak belt. Colossal engineering mistake by Bissell. Belt itself and its components are under way to much stress for the size they developed to perform their task. For Quality Control to let such an obvious blunder pass can only mean that it was intentional for reasons, Im sure, beneficial to Bissell and costly for the consumer. No telling how many people buy another entire machine when this rubberband of a belt breaks like it was intended. Bissell is not a consideration of myself or anyone I can enlighten.
Apr 18, 2008 | Bissell 8910 ProHeat Clear View Upright...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
939 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
