Question about Zebra LP2642 Printer
Eltron LP2642 will not print with standard driver.
Since downloading and using a Seagull Driver this printer will not respond to the standard driver. I can get it to print using the Zebra Designer drivers but this introduces other difficulties.Is there a way to set this unit back to the Factory standard for the parallel interface?
    Champion:
  • Zebra Expert
  • 285 Answers
Go to www.zebra.com and download compatible drive.
Posted on Nov 13, 2010
Hi there, I am printing on Zebra S600 using Seagull Scientific Driver, The printer only prints every alternate label that is prints one label and prints a blank. Thank you for your help
Skipping labels is usually a printer driver issue. You should use Seagull Scientific printer driver only if you are using the corresponding Seagull Scientific label design software. It is important to have the printer driver and label design software be from the same manufacturer.
Jul 01, 2011 | Zebra Stripe S600 Thermal Label Printer
I have a Zebra 105se printer. When I attempt to print labels, I am using bartender 9.4 to create the labels, the printer will not print using the full label. Instead it uses only the last inch of the...
Check to see what printer driver you are using. If you are using Seagull Scientific Bartender, you will need the printer driver from Seagull Scientific for it to print properly. You can download it from the Seagull website. Hope this helps!!
May 25, 2011 | Zebra 105Se Thermal Printer
Hi, On a Zebra S600 printer... How to change setup for print method (actually it showing up direct thermal) and we would like to change the print method to (Thermal trans). Thanks! Pierre Tardif
The easiest way may be to change your printing preferences at the driver level. We use Seagull Scientific Drivers (They are free to download).
If you use the Seagull Driver go to your Printers Folder, "Right Click" your printer and go to Properties
Then Go to the General Tab then Printing Preferences then Stock Tab then Print Method. Click on the Down Arrow and change to THERMAL TRANSFER.
If your using a label printing package make sure your settings are for Thermal Transfer since they can override default printer settings.
Good Luck
Mikeo@acebarcode.com
Feb 16, 2011 | Zebra Stripe S600 Thermal Label Printer
The driver for zebra p310 in Windows 7 is no existent
Install the windows xp Virtual machine on your window 7 machine it is free and will run the printer I am running like this at the moment
Feb 01, 2011 | Zebra Eltron P310 Thermal Printer
I need drivers Eltron Zebra P310CM for Windows 7
Hi I solve this problem with a program called CardFive this program provides several drivers inside when you install it in Windows 7. I install CardFive 6.3. Note. this program don´t install a printer driver in Devices and Printers in Windows 7, only provides you a interface to print cards with your Eltron p310 and you can choose other printer models discontinued. My printer interface is parallel and works in Windows 7 With CardFive 6.3 pro.
Jan 14, 2011 | Zebra Eltron P310 Thermal Printer
What driver can I download to use Zebra 2844 printer with Windows 7
You can use the free drivers from Seagull Scientific:
http://www.seagullscientific.com/aspx/thermal_95.aspx
Good luck, and come back with a testimonial if helped :)
Dec 11, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Hi there! I work with Zebra TLP2844 through
If you are using Bartender, Make sure to use the Seagull Scientific Zebra Driver. The zebra driver works (but not properly) with bartender. Download the driver from Seagull Scientific site. You can also email bartender tech support, their contact details are available from the help screen on the main bartender design screen. I have always found them to be extremely knowledgeable and helpful.
Jul 01, 2009 | Zebra LP 2844 Thermal Printer
How do I clear the memory on a zebra gk420d?
Download the Seagull scientific GK420 ZPL driver. Version 7.16.
Open the driver file, (Double click on printer icon in printer & faxes folder)
Click Printer, properties, tools, action, reset printer.
Play around with the Seagull driver, it is very useful, you can format memory, read files stored in printer memory, see forms, fonts, images etc.
The forms stored in the G series printers are not cleared by the normal methods which one would use on it's predecessor the 2844 models. The G series will maintain the forms stored in its memory even if you download new firmware, or reset it. This is actually a good thing, as it prevents you from accidentally erasing forms stored in the printer.
Feb 03, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Datamax WS6308 print error in .net
El controlador de Seagull es muy bueno y con muchos parametros, intenta modificar los parametros del spooler. Seagull driver is very good and with many parameters, try to modify the parameters of the spooler. buscar
Nov 24, 2008 | Epson Printer
Zebra LP2642 Printer Logo
442 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
