Question about Kenmore Dryers
Water heater will not stay lit even after replacing thermal coupl
I asked a question the other day and my wife deleted the return email before I could read it. So I'm going to ask again. My Kenmore propane hot water heater will not stay lit. I depress the red button to light pilot and it lights, but when I release the red button to allow it to stay lit on it's own, it goes out. It's about 6 years old. I've replaced the thermal coupler, but it still will not stay lit. I've blown out the two tubes that carry propane to pilot and the burner thinking maybe they were clogged, but still the pilot would not stay lit. Does this sound like the control valve?
  • 585 Answers
The pilot must encompass the thermocouple "bulb" in order for the thermocouple to generate enough current to keep the pilot valve on. You must also hold the red button down for a long enough period to get the thermocouple hot. If the pilot is not large enough, it could be due to a clog in the pilot orifice at the pilot itself. Sometimes a couple of passes over the end of it with fine steel wool is all it takes to clear it.
Hope this helps. Feel free to share what you found. Thanks.
Posted on Jul 16, 2009
  • Bruce Volkers
    Bruce Volkers Jul 16, 2009
    After I posted to this I went and read your original question. You obviously know to hold the red button. Something I forgot to mention though, you do need to put enough torque on the thermocouple connector nut to assure good electrical contact. If the brass tip of the thermocouple connector button is tarnished, try steel wool to brighten it up for good contact. It is a very small voltage at that point, any loss will make it not work.
  • Bruce Volkers
    Bruce Volkers Jul 20, 2009
    Did you get your issue resolved?
Sw6p suburban won't stay lit. My 6 gallon hot water heat on my 2007 camper won't stay lit, I go and light the pilot light and it lights but I turn the gas up and it blows out please help
the thermal couple is likely bad .
when you release does pilot stay lit or only as long as you hold the button .
if it stays lit then the thermal couple is good
if it only blows out as you turn on the heat then its draft issue.
May 09, 2015 | Water Water Heaters
Pilot light will not stay lit.
More than likely the thermal couple is defective. The thermal couple is a safety device that shuts the gas off if the pilot goes out. If it is defective the pilot light will not stay lit. The thermal couple is the device that the small copper line goes to. It is mounted beside the pilot flame and the flame much touch the TC for it to work. If the flame is not touching the TC bend it until it is in the flame. If it is touching the TC then replace it.
Jul 28, 2011 | Whirlpool Water Heaters
I have a Whirlpool gas water heater. The pilot light won't stay lit. It ignites, but goes out when I release the RESET button.
replce thermal coupling. and be sure to hold down reset button for at least 60 seconds after it lights. then let it up slowly and turn knob to start. have a good day !!
Apr 09, 2011 | Water Heaters
Pilot light is not staying lit. woke up to cold water.cleaned flame sensor. still no luck. any ideas?
sounds like a bad thermal coupling! if the coupling goes bad it will shut gas supply off as a safety precaution. it acts similar to a thermometer, if its bad then you will not get any gas through. it is screwed into gas valve and shuts the gas off. have a good day!! replace thermal coupling!
Nov 30, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
We change the burner for the water heater, it stay li ari=ound 35 minutes, heat the water and after is turning on completely, even the small flame don't stay lit. What we need to do?
you mean it is only staying on for 35 minutes, if this is the case, then readjust or replace thermal coupling, if bad it will not sense the flame or pilot light. it has to be in pilot light flame as to work properly. ( this is for a gas hot water heater). if bad it will shut gas off to heater.
Aug 05, 2010 | Water Heaters
Pilot won't stay lit in Reliance 606 gas water heater
The Reliance 606 has an enclosed thermal couple. Before you try taking that assembly apart take a wire brush to the bottom opening directly under the burner. There is a metal filter on the very bottom of the water heater. It could be that the filter has gotten filled with dust or animal hair. It took a serviceman 2 days to figure this out for me. The water heater has to have good airflow through that filter to work well.
Feb 13, 2010 | Reliance & 50gal Electric Water Heater
The pilot light & will stay lit. untill the burner cycles on/off
MAKE SURE THE BURNER TUBE AND ORIFICES ARE CLEAN. MAKE SURE YOU HAVE THE PROPER LP PRESSURE.
Oct 05, 2009 | RTO Atwood Water Heater - 6 Gal LP
Whirlpool hot water heater serial#0426117756 also know as american hot water heater The pilot light won't stay lit. Please help. I have been without hotwater for two days.
sounds like you need to replace the thermal coupling. This component sends a signal to the gas valve that there is a pilot
Jul 30, 2009 | Water Heaters
I replace my thermal coupling. burner doesn't ignite
is the burner assembly sitting pronperly on it;s cradle,, this will put it at just the right distance for it to ignite,,
Jun 15, 2009 | RTO Atwood Water Heater - 6 Gal LP
Dryers Logo
427 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
