Your best bet would be to contact Samick directly. Here's the link-
Samick Music Corporation
SOURCE: Hi,I am trying to date my husbands guitar.We
Try this site:
http://vintageguitarpro.com/serialyamaha.shtml
SOURCE: Guitar date of manafacture
What you have listed is an invalid serial number. If you go to:
http://www.yamaha.com/apps/guitararchives/guitarserial.htm
you can type in the serial number and get your answer.
SOURCE: Can i put my fender strat mexican guitar into
The Fender Stratocaster (in common with all Fender guitars) has passive pick-ups so should be plugged into the no 1 socket.
Whilst it will work in the No 2 input socket this has lower sensitivity and is intended for use with guitars that have active (battery powered) pick-ups.
SOURCE: wire diagram samick gregg bennett guitar
Here is the wiring diagram for a 2 humbucker, 2 volume, 2 tone, 3-way switch setup. The wires off the pickup may be a little different. Just attach the lead wire to the arm of the pot and the ground to the ground on the top of the pot. Should be very strait forward.
http://www.seymourduncan.com/pdfs/support/schematics/2h_2v_2t_3w.pdf
