Question about iRobot Roomba Discovery SE Bagless Robotic Vacuum
My roomba discovery will not operate on the clean or max buttons, will do the spot clean and goes forward then circles. Turns itself off and plays a little da do da do do do do. I have emptied tray, sprayed with compressed air.
    Sniper:
  • 61 Answers
If your Roomba goes "uh-oh", beep-beep-beep, that's a 3-beep error code, indicating that your vacuum motor is stalled. Remove the grill from the outside (back) of the dustbin and make sure that the impeller (looks like a fan) turns easily and is not clogged with dirt. Then try to run the robot with the bin ON but the grill OFF. You should be able to tell whether the vacuum impeller is spinning. If not, you'll need a new bin. You can confirm wth customer support by calling 1-877-855-8593.
Posted on Jul 28, 2009
Goes around in a circle and won't go forward was working fine untill my husband cleaned it out with tweesers
sounds like one of the motors on the wheels stop working making it go around in circle and not forward
Feb 16, 2011 | Roomba Vacuums
Roomba going in circles
Roomba going in circles. Called irobot and if reseting it (by taking out the battery, unplugging it from the charger, and holding down the power button for 30 seconds), didn't work, turn the roomba over, take a compressor and blow air into the front. Maybe a shop vac would also work. We cleaned out the whole thing while we were at it. And now it works just fine. The tech person at irobot was very helpful.
Mar 14, 2010 | iRobot 530 Roomba Vacuuming Robot, White...
Turns in circles, acts like it hits a virtual wall then stops
Reboot is probably not your solution. Your Roomba will react to invisible signals or 'interference' from other electrical appliances as well as the invisible wall boxes. You can clearly see how this happens when a Roomba gets near your computer or other device that is on. Also, the Roomba will go in circles when the dirt chamber is full or it thinks it's full. Try a thorough clean of all major parts including the brushes. Sometimes this activity will occur when the brushes get snarled on thread or carpet fibers.
Oct 09, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Discovery brushes won't turn. All bearings clean.
usually fibre jammed in wheel / brushes. try small hook run around spaces in unit toremove usuall human hair
Sep 14, 2009 | Roomba Robotic Floor Bagless Vacuum
Roomba Discovery 4210 was "played with" by 3 year old
go to roombaexchange.com and send it to them to get it ran through a battery of tests.
Apr 10, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Powers on but will not run, goes BONK when button is pressed.
OK, I have fixed my Roomba!! First I went out and searched the web for Troubleshooting info. What I found was the diagnostics that the factory uses to test them. So going through the diags. I found that 3 of the 4 IR Sensors along the front were not working. So I took the Top Cover off, then removed the Sensors from the front Bumper. I found a red wire that had been cut from the drop. Repaired the wire and all is good !!!!
Jan 02, 2009 | Roomba Robotic Floor Bagless Vacuum
Circles
Do you have it set on "spot"? This causes Roomba to start out in circles, expanding and expanding until a certain time and then returns by going in circles, making smaller circles, until it gets to its starting point.
Oct 21, 2008 | Roomba Robotic Floor Bagless Vacuum
Roomba Discovery wiggles back and forth and turns over and over
No matter your model Roomba, this occurs when Roomba has gone "crazy." Its brain is no longer working properly and you can usually tell this when you've cleaned the dickens out of it a few times and the behavior is still the same. There's only one possible user fix and that is to take out the battery, hold down the power button for 20-30 seconds then reinsert the battery.
If that doesn't do the trick, IRobot might send you something called an Ozmo which you put in the data port to rewrite Roomba's brain. Unfortunately this requires it to be under warranty unless you get lucky. Good luck, all!
Jul 12, 2008 | Roomba Robotic Floor Bagless Vacuum
iRobot Roomba Discovery SE Bagless Robotic Vacuum Logo
535 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
