Question about Ariens 34 In. Zoom Series Riding Mower
I have a problem with my ariens 34 inch zoom. Whenever I have the deck raised all the way up or lowered all the way down it runs fine, but if the deck is raised to the middle the deck belt starts shaking and the engine slows down.. What is wrong??
SOURCE: uncut strip in middle of 42 inch deck brand new
My first thought is that the blades are too short. If it cuts everywhere but in the middle, I'm wondering how it could be anything but that.
Charlie
Posted on Aug 14, 2009
  • 3 Answers
SOURCE: The engine will not stay running (Ariens 34' Zoom)
a lawn mower is not much different than a car, you still need 3 things to make it run: fuel, electricity, and a spark. you say it doesnt stay running, Before trying to make any repairs, ensure that you are using the correct fuel, also make sure the fuel lines are not leaking or crimped. if the lines seem fine, check the fuel filter and/ or fuel pump. though the mower is new, they can still have faulty componets.
Posted on Aug 16, 2009
  • 24 Answers
SOURCE: cutting deck of mower not lowering
Did you check the wires goin to the motor under the frame to see if one of them came disconnected? Or...you might need a new switch.
Posted on Aug 22, 2009
SOURCE: While trying to remove blades on Ariens Zoom 34,
you're gonna need to use an impact wrench on those spindle shaft nuts because they tighten themselves over time and they wont come loose with a ratchet and socket.
Posted on Dec 07, 2010
barterjoe
  • 344 Answers
SOURCE: my ariens zoom 34 belt
This machine is known for having belt guides installed improperly from the factory. Check to make sure none of the metal guides are touching the belt when installed.
Ps check with the machine off!
Good luck
Joe
Posted on Feb 11, 2011
Ariens Zoom 34 will not move forward or back
suspect a damaged belt or tensioner spring for the drive belt... these units have no servicable trans-axles. or did you just remove both rear wheels ???
Nov 27, 2013 | Ariens Zoom 34" (Stamped Deck) Zero Turn...
Does the zoom 34" zero turn have an oil drain plug? if so, where is it located?
some of the newer engines have a oil drain that you turn a quarter of a turn that it drains look at the bottom of the dip stick tube
Jul 09, 2012 | Ariens Zoom 34" (Stamped Deck) Zero Turn...
How to take the cover off the engine
start with upper covers and work your way down
Mar 27, 2012 | Ariens Zoom 34" (Stamped Deck) Zero Turn...
How do ytou adjustadjust the steering on ariens zoom mower
The owner's manual tell you. If you don't one. Go to www.mowersdirect.com/manuals/zoom4250pdf and download one.
Feb 18, 2012 | Ariens Zoom 34" (Stamped Deck) Zero Turn...
Ariens 34 zoom blade binds at mid-height blade
Sounds like the mower deck is lower on one side. I am having the same problem with my older tractor mower.
Jul 24, 2010 | Ariens 34 In. Zoom Series Riding Mower
Jul 24, 2009 | Ariens 34 In. Zoom Series Riding Mower
Blades won't turn to cut grass
On the chute where the grass comes out there is a black piece of metal under the edge of the deck held on by the 2 big thumb screws is probably bent. You will need to try to move the blade on the side near the chute by hand (Make sure the mower is not running when you do this) if the blade touches the black piece of metal it will kill the mower if you engage the blades and try moving forward. Anyway you need to take the black metal piece off and bend the corner out of the way (I used a crescent and clamped it to the hitch on my pickup). I am guessing i went over something like a street curb with the deck when it was to low and that bent it. Now when ever I move the mower from someones yard or drive it across the street I always raise the deck up all the way. I hope this helps
Apr 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens 34 In. Zoom Series Riding Mower Logo
104 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
