Brake rotors o4 sierra
Having trouble removing rotors (rear)
  • 883 Answers
Post email address and I will send...assuming you have calipers off, in the last detail, GM says to use a slide hammer with special end that touches only inside of rotor between vent ribs so not to damage rotor surface.
Posted on Nov 18, 2007
Having trouble removing rear disc brake rotor fron
This vehical has drum styal park brake shoes on the inside of the brake rotor so make sure the park brake isn't set and you can turn the rotor. If you can't turn the rotor you will have to look into this first if the park brake is set or sticking you won't get the rotor off if thats ok try spray with penting oil helps a little. I use a 4 or 5 lb sluge hammer and hit the rotor kinds close to the wheel studs about 5 times then hit the outer edge from the back side also works on the outerside. Don't be afread to hit hard I never broke one.
Jun 26, 2010 | 2005 Toyota Highlander
2000 GMC Sierra 3500 4x4 standard cab 5.7 litre single rear wheels,Please tell me How do get the front rotors off? Any help would be much appreciated.
The brake calipers will need to come off which is the hardest part for most. Have a " C" Clamp with an 8 inch throat is needed so you can press the brake pads inward to release pressure from the rotor. Upon removing the caliper the saddle if so equipt has to be unbolted from the steering knuckle. Two bolts hold this saddle on. You may not have one depending on the design caliper this truck has. Once these parts are off the rotor will come off
Apr 08, 2010 | 1998 GMC Sierra
How to replace rear brakes in 2005GMC Sierra?
jack up truck support it remove tire you should see the caliper,on the back side you will see two small bolts lossen the bolts remove it might require some prying support the caliper,check the rotor if has grooves in it it should be turned. use a c clamp to force the piston back in the caliper be careful of the rubber seal put the new pads on reinstall the caliper tighten the bolts start the truck pump the brakes a few times go back check for leaks if none put tire back on remove support lower to ground test drive
Nov 02, 2009 | 2005 GMC Sierra
How to remove the rear rotors on a gmc 2002 2500 hd extra cab 4x4
The rotors are one with the hub.s, So, you need to pull the axles , hub bearings. Good Luck
Sep 18, 2009 | 2002 GMC Sierra 2500HD
1999 gmc sierra rear brake trouble
Most likely a the caliper needs to be replaced. Could be more than that though, maybe brake hose. open brake bleeder and make sure you are getting brake fluid from the hose.
May 31, 2009 | 1999 GMC Sierra
Trying to remove and replace rear brake rotors
First, make sure your parking brake is off.
Remove the rear caliper and then the brake pad housing. In the center hub of the rotor the parking brake shoes are located. The may need to be loosen first. There is a hole between 2 of the studs you need to align at the bottom. Look in the hole with a flashlight and find the star wheel. Use a screw driver to turn the wheel up a few turns to loosen the parking brake shoes from the rotor hub.
After that there are 2 threaded holes in the rotor near the studs you put two 8mm bolts in and slowly tighten each and it will pull the rotor off the hub. They rust up pretty bad so use penetrating oil on them.
Apr 11, 2009 | 1994 Toyota Land Cruiser
2003 sierra rear brake rotors
there is many kind of brake system of ur truck here i will send u everything about the brake and i hope its help
Rear Brakes JC3
Rotor Discard Thickness* 18.50 mm/0.728 in Rotor Minimum Allowable Thickness After Refinish 19.0 mm/0.748 in Rotor Thickness (new) 20.0 mm/0.787 in Rotor Maximum Allowable Lateral Runout 0.05 mm/0.002 in Rotor Maximum Allowable Scoring 1.50 mm/0.059 in Rotor Maximum Allowable Thickness Variation 0.025 mm/0.001 in
Rear Brakes JC4
Rotor Discard Thickness* 28.50 mm/1.122 in Rotor Minimum Allowable Thickness After Refinish 29.0 mm/1.142 in Rotor Thickness (new) 30.0 mm/1.181 in Rotor Maximum Allowable Lateral Runout 0.05 mm/0.002 in Rotor Maximum Allowable Scoring1 .50 mm/0.059 in Rotor Maximum Allowable Thickness Variation 0.025 mm/0.001 in
Rear Brakes JH2
Rotor Discard Thickness* 28.50 mm/1.122 in Rotor Minimum Allowable Thickness After Refinish 29.0 mm/1.142 in Rotor Thickness (new) 30.0 mm/1.181 in Rotor Maximum Allowable Lateral Runout 0.05 mm/0.002 in Rotor Maximum Allowable Scoring 1.50 mm/0.059 in Rotor Maximum Allowable Thickness Variation 0.025 mm/0.001 in
Rear Brakes JH6
Rotor Discard Thickness* 27.50 mm/1.082 in Rotor Minimum Allowable Thickness After Refinish 28.0 mm/1.102 in Rotor Thickness (new) 29.0 mm/1.141 in Rotor Maximum Allowable Lateral Runout 0.05 mm/0.002 in Rotor Maximum Allowable Scoring 1.50 mm/0.059 in Rotor Maximum Allowable Thickness Variation 0.025 mm/0.001 in
Rear Brakes JH7
Rotor Discard Thickness* 28.5 mm/1.122 in Rotor Minimum Allowable Thickness After Refinish 29.0 mm/1.142 in Rotor Thickness (new) 30.0 mm/1.181 in Rotor Maximum Allowable Lateral Runout 0.05 mm/0.002 in Rotor Maximum Allowable Scoring 1.50 mm/0.059 in Rotor Maximum Allowable Thickness Variation 0.025 mm/0.001 in
* All brake rotors have a discard dimension cast into them. Replace any rotor that does not meet this Specification. After refinishing the rotor, replace any rotor that does not meet the minimum or discard thickness specifications.
Mar 15, 2009 | 2003 GMC Sierra 2500HD
Debree shields behind rear disc brake rotor rotted out.
Not hard to Replace. you will have to take the Caliper off of the Rotor and then Take the Rotor off, Repack the Bearings! And it is Right There!
Jan 18, 2009 | 2000 GMC New Sierra 1500
How to remove the rear brake pads from 2000 gmc sierra
there are two bolts behind the toward the ends these have to be loosen for the calipers to come off check out auto zone web page for complete instructions
Jan 10, 2009 | 2000 GMC Sierra
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
