Question about Mitsubishi WS-55859 55" Rear Projection Television
Digital Tuner Power Up
I have had this TV since 2001. When you turn on the digital tuner the picture comes on for a fraction of a second, a "thump" is heard, and the TV reboots (flashing green light). After several attempts I have been able to get the TV to turn on. This does not happen on the analog antenna. Any ideas? I am no TV expert, but have a great deal of electronics and soldering background.
  • 4402 Answers
SOURCE: Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Posted on Dec 15, 2007
SOURCE: Mitsubishi WS-65513 Flashing green light
please send me info on cap replacement, to fix flashing green light problem.
Thanks in advance.
Posted on Sep 26, 2008
SOURCE: Tv won't come on. It has a flashing green light on by the power button.
the tv is not come has a flashing green light model hd 1080.
Posted on Oct 22, 2008
  • 7 Answers
SOURCE: Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Posted on Jan 14, 2009
  • 6784 Answers
SOURCE: Mitsubishi TV WD-62527 will not turn on
Hi there, this is most commonly known as power board failure in the industry. the capacitors are blown. if you are experienced in inspecting circuit boards this will be helpful. you will have to disassemble and pull the power board and preform a break point test. the bown capacitors are easily picked out. they will be swollen and discolored. If you are not comfortable with disassembling this set, i suggest a service call. just tell the tech you are experiencing a power board failure.
Posted on Mar 07, 2009
SD Tech
  • 14553 Answers
SOURCE: The TV was working great
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
Let me know what error code you find and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
Post comment here if I can assist you further.
Posted on Sep 28, 2010
Testimonial: "The light blinked two times, then 1 time then repeated."
0 characters
1 Points
Idk if my tv is digtal ready it says its hd
The TV will provide an HD picture with a set top box connected to the HD input (AV4 or AV5). It does not have a digital tuner (only a NTSC analog tuner).
The manual is available here: . See appendix B on page 58 for the specifications.
I hope this helps.
Apr 19, 2011 | Philips 51PW9303 51" Rear Projection...
I would like to know if the Hitachi 51UWX20B television can be connected to the internet.
Your Hitachi 51UWX20B is an HDTV-Ready TV. No Digital Tuner. HDTV-Ready means that your TV set is capable of displaying analog and high-definition digital pictures, but without a digital tuner, it cannot receive the digital signal. An HDTV-Ready requires an external high-definition TV receiver (digital tuner) in order to receive HDTV signals. These external receivers can be called an HDTV Tuner, set-top-box, decoder or DTV Converter Box . So you will be required to purchase a converter box to receive over the air programming from an external antenna.
Jul 03, 2010 | Hitachi 51UWX20B 51" Rear Projection...
Can not get pip to work
Pip has its own tuner, try getting a cable splitter to split the signal into the tv. If you have digital cable you may need a second cable box to do this. If your cable provider still sends an analog signal the splitter will work.
Jul 10, 2009 | Toshiba 53H71 53 in. Rear Projection...
Philips 51PP9100D/37 Will Not Stay On
o.k. your internal digital tuner sounds like its goin. what you need to do is take the back cover off and trace where you hook up your
digital signal (cable,ant.hdmi).then you will see 2 silverish boxes one is analog,other digital. get refrence #s off of board of the tuner thats conneted (trace the signal input wire to be sure) then e-mail me
Jun 21, 2009 | Projection Televisions
Cant program digital channels.
Nothing. Digital Tuners Broke. I wouldn't be suprised if your TV freezes up momentarily (or for a long time) when you switch over to the Digital Channels.
This TV has 1 tuner for analog channels and 1 tuner for digital channels. You can probably find the Digital Tuner on Ebay and replace it.
Mar 04, 2009 | JVC HD-61G787 61" Television
Does anyone know if this tv is analog
the tuner on this tv will pick up the analog and the digital broadcast stations.
so yes you can get the analog stations , but you also get the digital or hd broadcast stations that are available
Mar 02, 2009 | RCA D52130 52" Rear Projection Television
Digital tv
Unless it says HDTV it is not digital.
Feb 16, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Sony projection tv with dual tuners; only one tuner appears to be working now.
To verify that the tuner is the problem, move the cable from the second to the first. If you don't get a signal, the tuner is bad. The main tuner is part number 859843000 and is available for $47.38 from
Oct 07, 2008 | Sony KP-51HW40 51" Rear Projection...
Misubishi warrior 2 intermitant pic freezes 1 second or less
Hello frogman,
The freezing of the picture denotes a loss of signal on a digital (Having a ATSC tuner) TV. If your TV is not digital (Having a ATSC tuner) then it is the device that you have connected to the TV (Cable Set-top Box, DTV Tuner, etc). In the likelihood that it is your TV I would suggest getting a better antenna first if that does not fix the problem you may have a tuner problem. However lets not look at it that way first. What we need to do is to determine if it is the TV of whatever you have connected to the TV.
First unhook the connection you have from the cable to your F connector of the TV (you should see snow or a blank screen) connect a antenna to the F connector of the TV, do you see a snowy picture or a clear sharp picture (snowy= NTSC tuner, clear-sharp= ATSC tuner). If the tuner is NTSC then check you cable device and the connection between your TV and the device and the cabling between the device and the wall. If the Tuner is ATSC then you will have to check all of your connections, and finally if the tuner is bad it has to be replaced by a qualified Tv repair shop.
I hope this helps,
Thank you,
May 09, 2008 | Projection Televisions
Off air digital signal
What brand of tv is it ? You could have a bad tuner or a change in the voltage supply line feeding the tuner . What type of antenna do you have ? outdoor or rabbit ears ? Also does it retain the channel line up or does it clear them as well ?
Feb 27, 2008 | RCA HD52W66 Projection Television
Mitsubishi WS-55859 55" Rear Projection Television Logo
23 people viewed this question
Top Mitsubishi Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Projection Television Expert? Answer questions, earn points and help others
