Question about Proview Televison & Video
I opened up a proview 3000 which the screen goes on and then off in about a second. I checked all capacitors on the power supply with a capacitor wizard. Every cap checked out ok and resoldered any dry solders I saw. Still no video. I do hear a sizzling noise coming from the main regulator IC on the hot side of the powersupply? I don't have an o-scope so I can't really tell though. Anyone fix a proview 3000 power supply..any know where I can get a new or repaired power supply?
SOURCE: PDP4294 PowerSupply Components
For the life of me, I can not find those caps online. Anyone have a direct line to the item? Mine also blew out yesterday.
Posted on May 12, 2008
ltfrc
  • 227 Answers
SOURCE: gateway fpd2185w capacitor fix question
Very important, use a pencil iron only, you can destroy the film on the board if you use too much heat. Go for the two bulging ones first. After you remove the capacitors if the holes fill over use a straight pin or similar to open the hole to accept the new part. Also whatch for the polarity on the one you remove, should have a + sign on one side. Make sure the new one goes back in the same way.
Posted on Jan 15, 2009
dave1645
  • 834 Answers
SOURCE: Same problem
not just lg i service all brands and this is a common thing they are cokking these parts
these set get really hot
Posted on Sep 20, 2009
  • 139 Answers
SOURCE: Is this something I can fix myself, do the
Yes, capacitors need to be soldered. But if they are Radial Caps it is easy to do. Just make sure the polarity (-/+) is correct or they will go boom.
Posted on Dec 30, 2009
Testimonial: "thanks!! Cold or hot solder? "
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
TV will not turn on. It was turning on via switch at back, but now will not. Proview 19
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Oct 13, 2012 | Proview Televison & Video
Screen only stays on for a few seconds then goes blank, you can turn the power off and the same thing will happen, I hook the monitor up to a different pc and the same problem.
the Proview PL926 uses the same power supply board as the Gate FPD1975 and it is known to have issues with the capacitors. Here is a link to information on repairing the board.
http://www.ccl-la.com/blog/index.php?s=pl926
I hope this helps, if so please rate my solution.
BuddyMc
Sep 18, 2011 | Proview PL926WBi 19" LCD Monitor
Screen comes on then goes off after 5 seconds
You may have power supply DC filter caps problem or the back light inverter circuits, need to inspect the inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 29, 2010 | Proview PL713B 17" Flat Panel LCD Monitor
Monitor screen goes black after it's on for about 10 seconds
Power supply will be the first place to look.
Jun 21, 2010 | Proview PL926WBi 19" LCD Monitor
Monitor is blank
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Proview PL926WBi 19" LCD Monitor
ProView PA40JK1A screen just went black one day.
No, There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Nov 17, 2009 | Proview PA40JK1A 40 in. LCD Television
Pl926wbi 19"proview monitor,screen goes black every 3 seconds,
Bad capacitors on the pcb boards internally unsoldering ad replacement is indicated.
Feb 17, 2009 | Proview PL926WBi 19" LCD Monitor
Pl916s proview 19 inch flat screen moniter
I managed to solve the same problem by replacing the six 470uf 25v capacitors. I have notice that the old ones has a bulging top.
Feb 07, 2009 | Proview PL916S2 Monitor
Proview 926 wbi monitor
have a look at the board open up the monitor and remove the boards and you have to look for doomed or colored caps, they will be obvious compared to the good flat caps on the board. replacing these will most likely repair your issues.
Oct 28, 2008 | Proview PL926WBi 19" LCD Monitor
Proview 3000
most likely bad capacitors in the Power supply.. fairly easy fix, if you can solder ok .
Oct 09, 2008 | Proview PM1619STA1 15.4 in. LCD TV
Televison & Video Logo
53 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
Tony
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
