Question about APC Heating & Cooling
Apartment central air vent
Some of the air conditioner vents not blowing air through.
    President:
  • 1,273 Answers
Hello.
It will usually be one of three things:
1. The vents are closed. Check that you can see up into the ducting. Usually there is a lever that opens and closes louvers behind the vent plate. If this is the case, you can open the louvers with the levers on the side of the vent plates to get your air. On older vents, the levers don't work very well, and may need replacement if this is the case. Not that you should, but I have opened the louvers with a screwdriver....It works....
-or-
2. A separated duct. Assuming that your ducts are overhead, the separation would be in the attic space.
-or-
3. An obstruction in the ducting. There may be a flapper that restricts air in one part of the ducting, forcing it more to the uther ducts. Sometimes these close off on their own accord and need to be reset for proper operation. An object in the ducting will cause the same problem.
I'd discuss this with your building maintenance team. The only item on this list that I'd take a crack at, if I were renting the apartment, is number 1. Even then, be very careful working on ladders. If you can see up into the vent, then there really isn't much else expected of you.
Hope this helps you. Regards, --W/D--
Posted on Jul 16, 2009
2012 Alpine 3700re. Why is the rear air main air outlet not blowing forced air?
Assuming you are talking about some kind of central forced air and not a roof air conditioner, I would say the hose fell off the outlet or the A/C unit itself. Do all the other vents blow cold air? If yes, remove the wall vent and look. If the hose is attached, go to the A/C unit and check there. Also, remote possibility some kind of critter got inside the hose and built a home, effectively blocking the airflow.
Not enough info on filters. Central air filter? Roof A/C filter? Engine air filter?
Manufacturers put so many different models of sleeper sofas in RVs, it's hard to tell which one you have. Your owner's manual should tell you. If you don't have one, look around. There might be a latch(s) somewhere. Or try pulling up and out or straight up.
Jun 30, 2015 | RVs
If you are using this inside your home with central air running do you have to vent it to an outside window?
Yes, it must be vented to the outside, even if you're using central AC, too. The reason being is if you don't vent it to the outside, the hot air and humidity that normally goes thru the duct and out the window, will stay in the house and your Central AC will have to run longer and harder to overcome this rise in heat and humidity. In addition, the room that the portable AC is in, will get extremely hot & humid.
Hope this helped you. Please let me know. Thanks.
Jun 15, 2011 | Haier CPN12XH9 Portable Air Conditioner
The air conditioner is blowing hot air, there is no water to drain
if it is also blowing cold air out of the other vents you need to vent the hot air its blowing outside
Sep 30, 2010 | NewAir ACP-1000E Portable Air Conditioner
Central air conditioning unit blows air but not cold air
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 29, 2010 | Amana Heating & Cooling
Amana central heat and air unit use to blow cold air through all the vents. Now the 2 hardest blowing vents close to the air handler barely even blow out cool air while all the other vents still blow very...
Visually inspect the duct run connections to the main trunk. It is possible that they have loosened and are losing air under the house. Also inspect the duct runs from the trunk connection to the vent connection. You want to check for any damage or other failure. It is rare to find dampers in individual runs in residential duct systems; however, it is another possibility.
http://www.youtube.com/watch?v=28ru4mlFMpI
I hope you find this information helpful. Good Luck in your endeavor! :-)
Mar 11, 2010 | Heating & Cooling
My small tank in the loft off the central heating is boiling over?
you have back syphening coming from your open vent pipe,the pipework needs looking at,could be that the open vent pipe is in the wrong place
Nov 21, 2009 | Ruud Central System Air Conditioner
Central Air- Breaker flips when AC is turned on
IT SOUNDS LIKE YOU HAVE A BAD COMPRESSOR OR A DEAD SHORT SOME WHERE IN THE UNIT
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Apartment Central A/C Unit Not Working Properly
Sounds to me you are low on freon and the evap coil in icing up
Jun 25, 2009 | White Rodgers 0754-1 Electric Water Heater...
1999 Ltd. The right vents blow hot air but left vents blow cold
Yes go to you have to get the codes from your ATC controls first...Hold down the A/C button and the Recirculating button at the same time and while holding the two buttons turn you left temp. control up. It should give you codes if not then it will just read 00. Once you get those find out what they mean...20, 46,52,or 54 means you blend door(s) are stuck down and have to come up to allow heat to flow. Go to www.heatertreater.net and it will tell you how to replace it or in my case I just fixed it by putting a screw in it to hold the doors up....But hey i'm cheap so i like quick fixer uppers!!! Try that and lemme know if it works...
Dec 05, 2008 | 1999 Jeep Grand Cherokee
Heating & Cooling Logo
71 people viewed this question
Top APC Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you an APC Heating and Cooling Expert? Answer questions, earn points and help others
