Question about Canon i475 InkJet Printer
Canon i475D Have error message 807.  Is that something that can be easily fixed or should I throw it away. Kaycee
Re: canon i475D
Have the same problem and nobody have the solution.
Posted on Oct 23, 2008
0 characters
3 Points
How do I fix ink absorber is full error message
Good luck. Canon is not help. I have cleaned these and the reset that you can only get online through a third party usually do not work and Canon will not give these out. Basically it is a throw away item. Messy trying to clean them only to not being able to reset the error.
Jul 31, 2014 | Canon Pixma iP4500 InkJet Printer
Error message "Refer to Printer Documentation 0-61011bed
My experience is that you need to leave the unit disconnected from the mains completely for longer than the other solutions suggest. Leave it overnight, disconnected from its power supply and with the power supply disconnected from the mains. This has worked for me twice. The first time I thought I had fixed it with something else. That did not work the second time and I realised it was something else I had done - leave it disconnected overnight (about to throw it away) before giving it one last try. I suspect that something needs to thoroughly discharge. Anyway, it is a simple solution to try. Best of luck! :-)
Nov 18, 2011 | Printers & Copiers
I have a Canon MP630. It is making a horrendous noise, like cogs scraping, very loud. Error message Service Error 5C00. Any ideas?
I have the same problem & it's driving me nuts! Can anyone help with this or is it a throw away job?
Dec 19, 2010 | Printers & Copiers
Canon i475D is showing error 807
This is basically ink tank error.
You have to reset ink tank
1.Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Thank You
Nov 22, 2010 | Canon i475 InkJet Printer
Error 1250 on PIXMA ip4300 printer. Despite open tray messae will not o away or allow printing to start.
the error message means there is something wrong with the printer and if the problem is not attended to, the error message will not go away.
In this case, the error message showing on your canon ip4300 is related to a door problem. It has something to do with the front door of your printer. I think the front door of your printer is closed of which is supposed to be opened.
So, the solution is to Open the paper output tray of your printer and the problem should be solved.
Good luck.
May 24, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
How to solve error 5100
the error you have is a carriage error it is more for the canon techs that eror code not usually a customer error code,
it probably not worth fixing if its not somethig simple like a dirty timing **** then throw it away cost you more than what the printer is worth.
canon tech
Apr 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Service error 5100
you have a carriage error, not worth fixing throw it away
Canon Tech
Apr 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I475d failing to print
uninstal the driver and reinstal it , recalibrate the printer.
Jan 16, 2009 | Canon i475 InkJet Printer
Canon i475 InkJet Printer Logo
653 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
