Question about GE 168997 Deep Fryer
Fryer stopped working
My fryer is barely 1 year old. When I turn it on the power light doesn't come on and the unit doesn't heat up. Of course the warranty is over so I have no recourse. Could any one help me with this problem? Any one having a similar problem? The outlet works so it's not the power source.
  • 3 more comments
  • Anonymous Dec 31, 2007
    My deep fryer is just over a year old as well, and one day it stopped heating up. My outlet is working and there is no evidence of the cord being damaged. ....what do I do now?
  • lil squee Jun 20, 2008
    Mine is doing the exact same thing. It is barely over a year old and one day in the middle of frying, it just stopped working. I tryed multiple outlets, so its not that. The power light wont come on, and it wont heat up... any fixes?
  • monica14 Aug 29, 2008
    My fryer did the same thing. We checked the cord to make sure there was power runing through and there was so I am at a loss. Any solutions please let me know.
  • Anonymous Jan 29, 2009
    I have used my fryer twice and in the middle of cooking the second time I used it, the power went off and it would not come back on. The outlet is working fine and there is nothing wrong with the cord. There was nothing caked on the heating element and the connection, as fare as I could tell, was secure.
    Any suggestions?
    This is a new fryer, I just got it for Christmas!
  • Vega-Ortega Tiara
    Vega-Ortega Tiara Apr 24, 2015
    The same thong just happen to me...the RESET button dont even work.
Hey Guys I had the same problem .. Make sure the unit fits into the grooves on the back side .. The Heating element grooves ..There is a reset ,, you have to use a very small pin to do it .. But I believe the problem is what I stated .. Also remember to clean out the oil pan .. If any gung builds up on the elements it will not HEAT up .. We went thru this same problem as you have all stated ..So check the two situations I have stated ...Good Luck
Posted on Nov 02, 2008
    New Friend:
See Now I believe common sense is not something very common to most people, so here, try this.
Take two small pieces of aluminum foil or clippings of electrical wire and put it in the two little holes on the plug.
Do not cross the metal tabs that the magnet sticks to.
Plug the cord into the fryer plug the fryer in and you should be good to go.
If not well I dunno....:-)
Posted on Nov 12, 2016
It seems that grease is on the electrical post (where the cord connect to the appliance) and that might be preventing optimal connection. Prior to figuring this as being the possible problem, I bought a new cord and it does not work either.Thus, I am concluding that the harden grease on the connecting post is the culprit. Any idea on how to clean that off?
Posted on Mar 05, 2008
I am having the same problem. The trouble shooting guide says something about a reset button, anyone know where it is?
  • 41 Answers
Going by the description you have given with the power light and not heating up and the outlet works - sounds like the power is not through to the element. Usual cause of that is a break in the power lead to the appliance. Now that could be near the plug where you plug it into the outlet (wall Socket) or where the plug fits into the appliance which is probably closer to the mark. Some appliances have fuses to protect the appliance in power surges. Check the power lead to the appliance for any burnt wiring. Might be just a matter of refitting the wire in the appliance or renewing it. Hope this helps.
Posted on Dec 02, 2007
Frymaster Dean Deep Fryers pilots light automatically go off
Will this heat up at all. Is it the same Model # as the one you .have some changes from the one you have for 2 years ago might have been made. check model # and make sure it is the same The light that go's out might be when the unit come up to the setting you put you Thermostat on meaning it heated up and will come back on when the temp drops and it starts to heat back up. it's that simple. if you just got this unit it should work if you turn the heating setting up . Let me know if the unit heats that is the starting point.
May 04, 2014 | Frymaster Dean SR42G Deep Fryer
Tank leaking oil
You didn't say how old is the deep fryer. There are 3 ways to do this job. A. take out the old tank and weld it ( most likely this is a very unreliable because when you start welding a spot, you may find another one somewhere else, and it never ends, and the welding shop will not give you any warranty for their welding too. ) and it is not cheap on labour alone. B. Replace the old tank from Imperial , They give you 90 days warranty on replacement parts. Please check out the labour first. C. This is the best way replace the whole unit with a new one they give you 1 year part & labour warranty. This is cheap compare with trying to repair the old one. You should shop around before you decided what to do. Good luck hope this can help.
Sep 24, 2010 | Imperial IFS50OP Deep Fryer
My deep fryer won't turn on or heat up.
Look for the safety switch that the heat element is supposed to push in when installed correctly. It may not be in all the way.
Jun 23, 2010 | Kitchen Appliances - Others
Ready light stays on but oil is not heating
Unfortunately, there's not much you can do about that. If it's under 3 years old, I would say call the manufacturer (800-726-0190) for warranty service w/ the model and serial numbers to see if there's anything they can do, but just so you know their warranty does not cover shipping at all for warranty service. Sorry. :\
Aug 28, 2009 | Cuisinart CDF-100 Deep Fryer
Emerilware fryer wont power up FR7009001
You can go to T-Fal website they have replacement parts the new element is $101.99. i need a new element also but thinking of buying a whole new unit and keep old one for parts
Jun 11, 2009 | Emerilware FR7009001 Deep Fryer
Deep Frier power indicator light is on but will
Most fryers have what is called a hi limit. When the oil temp reaches a certain Max temp this switch opens the circuit and will not allow the unit to heat. On commercial fryers, the hi limit has a really small red plunger button. Push it in to reset.
Mar 28, 2009 | Kitchen Appliances - Others
T-fal 4017 deep fryer will not turn on
the reset switch is a miss print in the manual. call this number 1-800-557-4825 they will replace it for free if it is still under warranty
Jan 20, 2009 | Rival CZF530 Deep Fryer
Rival 3-L Cool Touch Deep Fryer
Hi, Its very possible that you have the wrong power to your fryer. I noticed that you said that you tried to plug it in. If it does not seem to fit or if you had to bend anything on the plug to make it fit you need to have an electrician check to make sure you have the correct power to the fryer. The wall outlet will have the power information printed on it. The manual will give you the power requirements. It the plug fits ok, check your breaker for that outlet. Good Luck. If this solution does not rate an (Almost There) Please do not rate.
Thank You,
Oct 07, 2007 | Kitchen Appliances - Others
GE 168997 Deep Fryer Logo
1,815 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
