Question about Rangemaster Professional Ceramic Hob Electric Cooktop
How do I replace the element on a ceramic hob
Telefunken spare parts australia
Try turning off the power for a short while to allow the p c board to re set itself turn it back on and individually turn on each elements for a few minutes. Good luck
Ray
Apr 16, 2014 | Kuppersbusch Glass ceramic induction hob...
Lamona ceramic hob
Ceramic cooktops need the correct type of pots or they leave marks,check your instruction manual.
Mar 11, 2014 | GE Cooktops
The top of my halogen hob has cracked from top to bottom thro the centre is there any way of repairing it? it is a 5 ring creda rangemaster
you cant repair the glass but you can get the ceramic glass as a spare part. you will need the exact model number to get the correct part once done your hob looks brand new. if cracked through one of the zones you could chack there is no damage to element or themal cutout running across the centre of the element before proceeding.
Aug 22, 2010 | Cooktops
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
I can't unset the child safety lock on my diplomat ceramic hob
get the model number if a cooktop will be underneatth on sticker.... go to kitchaid.com and locate thier manuals and literature section where u can download a copy or print one out.... hope this helps
Feb 05, 2010 | Cooktops
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Neff T1722 so 02 ceramic hob
its normal for the ceramic hob to ON & OFF coz of the sensor inside the unit to protect for overheating.same here in phillipines.its normal.tnx gerbee
Jul 28, 2008 | Neff 23 in. T1443 Electric Cooktop
Rangemaster Professional Ceramic Hob Electric Cooktop Logo
1,008 people viewed this question
Top Rangemaster Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Rangemaster Cooktop Expert? Answer questions, earn points and help others
