Question about Jensen CD-3010 X CD Player
Does the small jensen power button light stay on all the time?I installed it on a boat, the dim blue light its lit all the time!
    Problem Solver:
  • 6 Answers
Yes it does. I installed the same unit on my boat and ran an inline switch to the battery to turn it off so as to not wear the battery down.
Posted on Mar 01, 2010
JVC KD-AVX1. The head unit will not "turn on" when the power button is pushed. The display just stays off. The face lights up when you press the eject button and opens up and you are able to feed...
is this a headunit you have just installed? if not then I am not sure, but if it is, try swapping the red and yellow wires over. One should have permanent live, the other should be switchable. (unless you want the headunit to stay on when the ignition is off, in which case put them both to a permenant live feed.)
Hope this helps.
May 09, 2011 | JVC KD-AVX1 Car DVD Player
I have 3 power wires on my jensen mcd5080 marine cd player/receiver,a+12dc switched (acc)red wire ,illuminationdimmer orange wireand a +12vdc battery (memory yellow wire do i hook them all to the same...
If you want the Jensen to shut off with the key the red wire has to go on the acc. side which is key on power. If you go direct to the battery it will stay on all the time, unless you shut it off at the switch. The other memory goes to the battery, illuminate dim should go to key side.
Jan 07, 2018 | Car Audio & Video
What was the code did all work cause i can not get it to work at all
Hello
Just try one amoung the following codes. I've only these three codes are available with me for Jensen Tv.
{ 0004 _0009 _0133 }
Proceedings
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Note:- If one amoung the above four codes did't work, try the other after the TV is switched off and switch in again after some time, say at about 10 seconds, and try the other. Not enter the code continously without turning it off, after one code won't work. Ok.
__________________________________________________________________________________
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Oct 25, 2010 | Jensen TS2050J 20" TV
Television will not come on, blue light stays lit
jtoddweaver, Check out some YOUTUBE videos of lcd monitor disassembly and lcd monitor repair so you will know what you are looking for that is bad on your unit's "switch-mode-power-supply" printed circuit board. If you do the repair to the board, please document your "tear-down" with video or digital still pictures so you can complain to OLEVIA about poor quality capacitors they installed on power supply and also aid in the reassembly process. Do some reading in the fixya profiles of "budmrtn" "buddymc" "12fixlouie" and follow links you find there. Bye for now 12fixlouie
Jul 30, 2010 | Olevia LT37HVS 37 in. LCD HDTV
After shutdown of gateway laptop blue power button stays lit.....
Hi this sounds like your computer is in hibernation mode as opposed to shut down mode. Could you check and see as if running Vista many people assume that clicking on the brown power type selection under start that they are shutting down where as this actually only hibernation mode and clicking on the little arrow to the right of this and selecting shutdown is the way to go.
I hope this helps
Apr 07, 2009 | Gateway MX6441 Notebook
Need remote code for programming a bell expressvu receiver
Here for the Jensen remote just click below;
Here is link to the manual:
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Here is some helpful information I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Here are some codes I found for the Jensen 323:
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
Hope it may help you;
Regards,
VOTIT
Jan 27, 2009 | Jensen 143307 Remote Control
JER 323
Auto Program JER-323
1. Press the device button, ex. TV and the power button for 3 seconds until the on/off button stays lit.
2. Once the on/off button is lit, press the on/off button until the unit turns off.
3. When the code is located, press the stop button at the bottom to save the code.
May 01, 2008 | Jensen 143307 Remote Control
Power supply for dmtech wt20xt lcd tv
I have DMtech 20" with intergrated DVD and had the same problem- blue light lit on power switch but no response on power up.
I noticed that when the power cord was unplugged from the back of the TV the green LED on the power supply would brighten and consequently dim when plugged back in. Sometimes the blue light on the power switch would strobe very quickly but you had to look carfully for this.
I repeatedly unplugged the DIN type power plug from the back of the TV untill the green light on the power supply stayed a constant bright and there was no strobing on the blue light on the front of the TV, when I powered the TV on at this point the button worked again and the tv powered up with the silly tune then life in the screen. I did have to do this a good few times (I'm tenacious) but it did work!!!!!
Hope this helps someone else, cheers.
Apr 11, 2008 | Televison & Video
JER 323
Without the code on JER-323: 1. Press the device button - example - "TV" and the power button for 3 seconds until the on/off button stays lit. 2. Once the on/off button is lit, press the on/off button until t ...morehe unit turns off. 3. When the code is located, press the stop button at the bottom to save the code.
Mar 08, 2008 | Jensen JER-822 Remote Control
Jensen CD-3010 X CD Player Logo
96 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
