Question about Apple Vision 750 Monitor
Viewsonic VX910 I am having a problem with my screen going black I took the monitor apart and on the yellow circuit board I found that 2 of the little black boxes were cracked and one had burned the connection the some of the metal leads.
  • 72 Answers
Sounds as if your monitor's board is burnt out. I think its time for you to invest in a new one. You can recycle your old monitor for parts. Donate it to an E-Waste recyclers because you don't want that lead in the landfills.
Posted on Feb 18, 2008
The screen will suddenly begin flashing on and off for long periods of times.
the inverter board has an issue, take the monitor apart and see if there a Capacitor that is bulged or leaking a brown goo from it, if there is a blown capacitor then replace them with same type and heat rating. after than put the monitor back together.
hope this solves the problem.
PS the inverter board is the Board with the big transformer on it its normally the yellow/brown colored board.
Feb 19, 2010 | ViewSonic VX910 19" LCD Monitor
Monitor turns black after 2 seconds, Viewsonic VX910
Check the power supply first for bad caps, then check to see if you do have 12vdc feeding the the inverter circuits, worst case will be the lamps, see example of failed VIEWSONIC monitors due to bad caps:
Jan 21, 2010 | ViewSonic VX910 19" LCD Monitor
I need a part for my viewsonic vx910 LCD monitor, its basically a power unit . who can i contact or where can i go to order one, I live in australia. The sticker on this power board, is P/N AS02B012D24. I...
you can and see if they have any. If not they could direct you to Viewsonic. If you have no luck let me know and i will try my contacts for you.
Jan 03, 2010 | ViewSonic VX910 19" LCD Monitor
ViewSonic VX910 monitor has a power supply issue.
Your monitor have a bad condensator in the PSU.
The only thing to do is to replace the Power Supply Unit (very expensive, more than a new monitor) or if you have electronic tools, found and replace that condensator.(cheaper way...)
Have you connected your monitor with a new power cord ?
Best Regards!
Jun 29, 2009 | ViewSonic VX910 19" LCD Monitor
Two problems vx922 Black screen of Death and vx910 no power
You may want to tey another computer or another cable or update your video card drivers. Otherwise look very closely and see if you are able to see a very faint image of your background picture or icons if you have any.
Really im not kidding it might be a backlight issue.
Nov 18, 2008 | ViewSonic VX922 19" Monitor Flat Panel
ViewSonic VX910 19" LCD...
I had the same exact problem. I pulled the power supply/inverter board out and found what alot of people have seen. The T1 transformer has blown. Replacement board link here.
Apr 22, 2008 | ViewSonic VX910 19" LCD Monitor
The problems is my monitor (VeiwSonic VX910) is blinking evey few seconds from destktop screen to black screen. help!!!
PSU- Board, Rev.C
Item: B-PS-0204-0076
Compatible with: VX710 VX910 VX912 VX924
(This item has been discontinued and not available to order.)
Please order B-00002481 instead. Your Price: US$45.00 Each
Jan 08, 2008 | ViewSonic VX910 19" LCD Monitor
LCD monitor problems.
If the monitors use seperate plug in power supply EG 12 to 24volts it could be that at fault.
Or it could be the invertor at fault.
I have had some success repairing invertors if you can use A meter remove invertor Panels & check accross the coils with meter set to ohms all the coils should read identical chances are you will find one set of windings either dead short or open circuit. This will be the faulty coil hopefully as your monitors are all the same make the coils will be the same.
Carefully desolder faulty coil & fit one that reads good from a doner board.
Look for any SMD type fuses & check or replace them & thats it I have done quite a few now using this method.
Give it a go.
Dec 30, 2007 | ViewSonic VX910 19" LCD Monitor
Apple Vision 750 Monitor Logo
112 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
