Laptop computer and wireless router problem
I have a Linksys Wireless-G router and I am using a Dynex wireless-G adapter. The laptop is a Toshiba Satellite.
I installed the wireless connection with no problem and was able to surf the internet. As soon as somebody logged off and logged in as a different user the internet connection was lost. I had to go through the whole process of establishing the wireless connection again. This also happens when the computer is shut off or the adapter is unplugged and plugged back in.
It appears that there was a Belkin adapter installed on the laptop at one time. It is not my computer so I will have to look at it again and make sure that it was uninstalled. Would that make a differenece?
I was at my wits end so I hope someone can help me. Also, I read somewhere online that the Dynex adapter is junk so maybe that is the problem. Would it be better to buy one of the more expensive notebook adapters?
Thanks for your time and consideration.
  • rochestra Nov 19, 2007
    I already received a solution froma another web page.
  • 611 Answers
Re-installed the driver of adapter and check the wireless zero configuration is start is start then off then on after then check and one more thing yuor firewall will be disable
Posted on Dec 12, 2008
I have an old laptop that has a linksys wireless-b notebook adapter and my new computer with a linksys router attached is a linksys dual-band wireless-n. I can not get the notebook to link to the router...
Most of the newer routers use a newer type of encryption (WPA or WPA2) which is not supported by older 802.11b hardware.
Either set the Linksys router to use WEP encryption, or get a newer 802.11g card for the old laptop which can use WPA or WPA2 encryption.
Older versions of Windows XP also need to be upgraded to Service Pack 3 or apply this patch:
Mar 22, 2011 | Linksys 2.4 GHz 802.11b Wireless - B...
We have a new laptop, and desktop and a linksys
by default all laptop has wilreless adapter inbuilt in it
but desktop doesnot have wireless adapter
if you have wireless adapter on all laptop and desktop
in that case
reconfigure wireless setting of router
changed ssid and network key
Mar 14, 2010 | Linksys Computers & Internet
Can't connect through my wireless G network adapter.
Give the default gateway address of your laptop computer in the desktop computer. this will solve your issue.
Sep 02, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Using a linksys g adapter card in my laptop cannot get internet
U have to configure the router.Then & then your internet will work.You can see the instruction set given with the linksys router or instruction set cd.Follow the steps,which will ask you ip,user name,password etc. information.Fill the right information save & reboot it must work.
Jan 03, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
Nov 22, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
Oct 21, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Toshiba WRC 1000 as a Wireless bridge
lets get the picture right. laptop connects to a wireless router. then u want to plug into laptop ethernet wan port of linksys ? you have to set router manual settings to gateway which is ip of toshiba... this is a fun topic. ive connected xbox360 to laptop this way.. never tried router. "fun times ahead!"
Oct 10, 2008 | Toshiba WRC 1000 Wireless...
My lap top connecting to my wireless system.
Your computer is not yet connected to the wireless network of the router. Also, make sure that your wireless computer has a wireless adapter installed on it. You may verify it on the Device Manager. If you're using a laptop with built in wireless adapter , make sure that the switch for the wireless connection is on so that it will detect the signal of the router.
Try configuring or verifying the wireless settings of the router first by following the steps on this link:**&p_li=&p_topview=1
After configuring or verifying the wireless settings of the router, connect your wireless computer by following the steps on this link:
If you cannot still connect wirelessly, let me know of the following:
- model number of the router
- operating system of the computer
- wireless adapter installed on the computer (built in or external)
- brand of wireless adapter installed
- wireless settings of the router (SSID, wireless security)
May 13, 2008 | Linksys Wireless-G WRT54G Router
Drivers 4 Linksys BEFW11S4 ver. 4
Your wired network adapter will talk to a wired router without a driver for the router on your computer. Your wireless adapter likewise will talk to your wireless router without a driver for the wireless router on your computer. Your wired and wireless adapters however do require drivers and the wireless adapter can require configuration. Please provide the manufacturer and model of your computer so I can learn about your wireless adapter and we can work to get it connected to the router.
Do you currently have your router connected to your internet service providers connection and do you have another wired or wireless computer successfully using this device to access the internet?
Dec 09, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Computers & Internet Logo
215 people viewed this question
David Payne
David Payne
