Question about Mitsubishi WS-55809 55" Rear Projection Television
I have taken the back off of this, cleaned everything and cant find out what is wrong. My TV is having a "bow tie" affect and the colors are off on the outsides of the screen but the middle is a perfect picture. The left side seems to be the worst though. I looked at the convergence components from above and everything looks soldered. Maybe i need to take the board out and look at the soldering from underneath maybe. ..... Now, i took the memory board off and checked the convergence chips at a closer look and to look at the underneath for soldering. Everything looke soldered. I put it all back together and now the tv wont turn on. The green light comes on for only a second and shuts off and the tv never turns on. Can anyone help me with this problem?
    Sergeant:
    Champion:
  • 226 Answers
MOST OF THESE SETS HAVE A DUAL SETUP YOU NEED TO REPLACE BOTH @ THE SAME TIME,IF YOU REPLACE THE 1 IT PUTS TO MUCH STRAIN ON THE OTHER AND YOU END UP WITH THE SAME PROBLEM HOPE THIS HELPS
Posted on Jul 16, 2009
Camry 94 dome radio and clock out
Hi, I'm Peter, Do you have power to the fuse? Use a test light or meter. It is possible he may have cut the wire into when ever he remove the alarm. If you have power to the fuse and the fuse is good you need to look for a ground wire that he may have taken loose when he removed the alarm system and didn't bother to hook the ground back. Check also for a relay that may affect these. On my cay there is an illumination fuse that affects all of those and it also is tied into the headlights but you would not know it without removing the entire fuse box and running continuity checks on everything. You may be surprised at how many different things are tied together . Hope this gives you a starting point.
Apr 18, 2014 | 1994 Toyota Camry
How to tie a big bow on a Christmas wreath
I think you have this posted on either the wrong site or the wrong area, this area is for Projection television questions.
I would just buy a wreath with the bow already on it.
Dec 11, 2012 | Televison & Video
I have a Mitsubishi WS55809 that I purchased in 2002, and my kids have been using it for gaming. As they are playing, the screen convergence will change constantly from a normal image, to a "bow...
Unless you've moved the unit lately, or the kids have treated it roughly, it's probably not the mirror, which is fixed in place with screws on this model.
You can also take a look at this website here, which describes some solutions to bowing problems, specifically replacing the convergence ICs. However, this is expensive, provided you can still find parts, and probably isn't your problem, anyway.
Since whacking the unit fixes and un-fixes the problem, it's more than likely a connector that's loose. If you know your way around the inside of a TV, you can unplug, clean, and re-plug the various boards and connectors, especially the convergence and deflector boards. That will likely solve your problem
CAUTION: If you don't know your way around the inside of a TV, DON'T OPEN IT! Even after unplugging the TV, some of the wires inside will have enough voltage to cause serious injury. Better to be safe than sorry.
Feb 28, 2011 | Mitsubishi WS-55809 55" Rear Projection...
How do you tie a bow tie
Hello thanks for using fixya
To know how to tie a bow tie. See the following videos carefully, They are surely going to help you out,
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Jan 30, 2011 | YouTube Videos
Bowed picture on Philips 55pp9352 after replacing IC's
You must have mishandled the ICs they are static sensitive, and unless you used Sanyo ICs then you will have problems. The convergence is obviously not working so the TV will need the digital convergence board repaired or replaced, also the PIP board is suspect I have seen plenty of these tvs and believe me I earned the $ 350 we charged. These sets are very difficult to work on even for a trained tech. the best thing to do is to have a repair shop do it and you will have the assurance that its done correctly, and the work is guaranteed, That makes sense. ( I will not be able to respond to any further inquires)
Jan 04, 2010 | Philips 55PP9352 55" Projection Television
Mitsubishi ws-55809 distorted picture
Sounds like you are having a convergence error.
What you could do is either replace the TV or have some wires/circuits/boards replaced.
Shop around for prices.
If you're lucky you'll find someone willing to do a free estimate, as replacing anything on these will set you back a few hundred...at least.
Hopefully, in your case, the problem can be solved by tightening a screw or two.
Jul 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
My problem is that the picture in the screen is out of focus.
I´m changed the canon to TV projection the green and is go out the convergencia above and
side right I don´t know how iter in the menu inter could you tell me how it these. thank you..
Feb 05, 2009 | RCA HD52W59 HDTV Projection Television
Picture is blurry and is shaped like a bow tie on my tv
This is a convergence problem that you can fix if you can solder. Let me know if you wish to attempt the repair and I'll post additional details and instructions.
Dan
Oct 10, 2008 | Mitsubishi VS-55707 TV
Mitsubishi WS-55809 55" Rear Projection Television Logo
50 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
