Question about HTC Touch HD Smartphone
Music function not working
On my touch hd, the music tab is unable to find any music, however i can locate the music files in the ''My Documents'' folder. The Windows media player works fine... thanks!
    Problem Solver:
  • 5 Answers
I had to play around with my phone after I had it replaced and they did a mirror copy of the software. I was previously using a memory card to hold my music because I am a game freak and have tons of stuff on my phone. Try downloading your music to "My Music" after clicking the phone icon on your "My computer" window on your computer. Once I added a song or two there, then it went and found the rest of the music just fine. It would show up in my library for the touchflo tab, but not in now playing. I will check back later to see if you still have problems. Good luck!
Posted on Jul 19, 2009
I deleted by mistake during a sync with PC, all files in the folder My Documents on my HTC Touch HD, including UAContents and original wallpapers. Can I recover these files ? Thanks. Tony, Sibiu, Romania
it is located in your phone system.(built in) you can find it with the help of any file manager. or simply restore your phone with a hard reset, then the files will resurfaced bur be sure to backup your data.
Mar 14, 2011 | HTC Touch HD Smartphone
Tip
Moving the iTunes Music Files to a Different Hard Disk/Folder If you are low on...
If you are low on disk space in your iTunes folder then you can move these music files to another hard drive and keep your music library in tact without the need to create your music library again.
If you want to transfer your iTunes to an external USB hard drive, make sure that it is powered up and connected to your computer before opening iTunes.
Opened iTunes, click Edit and then Preferences. Click the Advanced tab.
Make sure the Keep iTunes Media folder organized checkbox is checked, and click Change.
Then select the location where you would like to move your files to. Click Select the Hard Drive and Folder or OK once you’re done.
The files will not move into their new positions by themselves –To do this – click File, Library and Organize Library. Check Consolidate Files.
When this process has been completed, go to the new location of your iTunes media and check the music files to see if they have migrated across correctly. Also play one or more tunes to test the music files.
The redundant iTunes music files can now be deleted from the original iTune location (C:\Documents and Settings\…..…\My Documents\My Music\iTunes). Delete everything from iTunes there except files titled iTunes Library.itl and iTunes Music Library.xml. These are still needed.
on Jun 05, 2010 | Computers & Internet
I used to have ripping in my media center/player now it is gone how can i get it back
first you need to open your media player.
then follow the step.
  1. goto tools> options
  2. select copy music tab.
  3. you will see copy music location.
    (tips. by default it is (..\\My Documents\My Music))
  4. you can change it by clicking on change button.
if you want your ripped file then goto that location.
if it helps you, then pls rate it.
thank you.
REMEMBER US FOR ANY DOUBT.
Oct 14, 2010 | Computers & Internet
How to save any music file in storage memory via blootooth
Option 11. Transfer the music file from PC to mobile 2. Using the File Explorer browse to the music file. It will be stored under Device>>My Documents (default location) 3. With Stylus hold on the music file you will find options to Cut, Copy.. choose the desired action 4. Browse to your storage devices and to your desired folder 5. "Paste" the file
Option 2 You can directly set the memory card's folder as the bluetooth receive folder. This settings can be found under Settings>> Bluetooth>> FTP
Jul 07, 2010 | HTC Touch P3450 Smartphone
Touch flo background...
its probably the default but with windows you most likely cant change it
Jan 22, 2010 | HTC Touch HD Smartphone
Lost the music while updating to itunes 9 now itunes does not recognise my devices
My first question to you is what operating system are you using?
Additionally, even if iTunes 9 doesn't see some of your your music files, they still should be there.
As an example, my iTunes music files are in the following folder: C:\Documents and Settings\Gordy\My Documents\My Music\iTunes\iTunes Music
Your location will be similar to this. Also, when you load iTunes, choose the Help tab and that should be able to lead you through it.
Not knowing what you specifically have, this is all I ca offer at the moment.
Oct 03, 2009 | Apple iTunes
The iTunes Library file is locked, on a locked disk, or you do not have write permission for this file.
1. Open Finder. Goto Music > iTunes > and locate the following files.
iTunes Library.itl
2. For each file:
Right click on each file.
Click on Get Info
Under the Sharing & Permissions Tab: Make all the Privileges 'Read & Write'.
Close the Get Info box
Open iTunes again.
This worked for me on Snow Leopard.
Aug 13, 2009 | Apple iTunes
Need to transfer music to my sisters phone from my htc touch hd using bluetooth
you have to beam it to her phone. its called beam on htc not bluetooth???goto start, programs, file explorer, then find the file where your music is. click menu then click beam file and select her phone. hope that helps
May 08, 2009 | HTC Touch HD Smartphone
I CANT DELETE MUSIC FILES FROM MY HTC Touch HD
YOU HAVE TO CONCECT ON COMPUTER WITH ATCTIVE SINC AND YOU CAN DELETE OR AD FROM THERE.
May 07, 2009 | HTC Touch HD Smartphone
Unable to send pic via HTC bluetooth
1. When someone sent file (photo, music..) to you, usually it is store at My document.
2. If you want to sent file: 1. open your bluetooth by start-setting-connection-bluetooth after check both checkbox. Then go to file explorer, select the file you want to sent by hold that file and choose beam. After waiting for device check for bluetooth and then click on your bluetooth name you want to sent.
enjoy it!!
Nov 17, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
HTC Touch HD Smartphone Logo
76 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
