Question about Nelson Sprinkler: Traveling Tractor
Nelson traveling sprinkler broken plastic part
My sprinkler must have tipped over and the black plastic part that the sprinkler arm is attached to broke. Part of it is still in the shaft. It looks like a nut with threads that attach to the sprinkler arms. I checked the Nelson web site and the sprinkler warehouse site and did not find the part. Can this be replaced?
I just took mine apart about a week ago. If, I recall correctly, you broke the T piece. That black plastic or nylon nut that is still connected to the transmission should thread off fairly easily.
I expect you can buy the part from Nelson.
If, solution #1 is correct and you find you cannot get the part, I've done some truly amazing repairs with that epoxy product called PC7. Depending how much of the part is broken and or missing, you might find a combination of what you have plus a brass T fitting plus the PC 7 will get it working.
You have nothing to loose.
Posted on Dec 08, 2009
  • 76 Answers
If some part of your sprinkler is broken you should replace the whole sprinkler .
Posted on Jul 16, 2009
2006 trailblazer washer wiper nozzle removal replacement
the nozzles just snap in from the top.... you first pop the cover at the pivot point of the wiper arm to access the nut. remove said nut. remove the wiper arms (a puller is very useful to avoid damage) , then Remove the air inlet grille panel (held in with pushpins and small 1/4in or 9/32in bolts. disconnect the hoses and squeeze the two tabs that hold them in. because they snap in from the top, i have seen people crush and brake their old nozzles with needle nose pliers. pull the hose through the hole and attach it to the new nozzle...... NOT the recommended procedure, rent or buy a puller that looks like a small two jaw gear puller to save yourself a big headache (mine was only $45). good luck
Nov 01, 2014 | 2006 Chevrolet Trailblazer
Sprinkler arms came off and water shoots straight up
You just have to screw the arms back on. There is a plastic white bolt that is attached to the arm it screws on to the tractor.
Sep 04, 2013 | Nelson LR Rain Train Traveling Sprinkler...
Sprinkler arms do not turn and the wheels do not turn on Nelson 1865
Here is a tip about how to get parts foryour traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
TravelingLawn Sprinklers
heatman101
Aug 08, 2011 | Nelson LR Rain Train Traveling Sprinkler...
My son tipped our neighbors tractor sprinkler over and broke the plastic valve piece that holds the arms. Any way I can get that valve? Has three holes one from the bottom and the two for the sprinker...
You have to buy a arm kit from Nelson or one of their vendors. You get 2 new tubes & the plastic tee that goes in the center of the motor. There around $15.00
Jun 16, 2011 | Nelson Sprinkler: Traveling Tractor
Tractor sprinkler. the plastic t that attached the arms has broken. i ordered a new part with the t, and two new sprayer arms. cant figure out how to remove the broken t. tried pulling as i unscrewed...
Make sure you are holding the shaft that goes down into the tractor still. You may need a pipe wrench to hold it tight. If it is still stuck you may need to use something like PB blaster to loosen the joint. Gently heating the joint with a propane torch and letting it cool back down might break it free as well.
Jun 06, 2011 | John Deere Gilmour Traveling Sprinkler -...
The arm that turns that water comes out of is broken
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Apr 17, 2011 | Nelson Sprinkler: Traveling Tractor
T fitting on top of tractor that the sprinkler arms attach to
To remove: Hold the plastic nut under the "T" arm assembly and use your other hand to unscrew the "T".
To replace do just the opposite. Do not over tighten, you can crack the retaining nut.
Mar 31, 2011 | Nelson Sprinkler: Traveling Tractor
I need part number 77377 plastic motor assy. I'm looking at parts list for Nelson 1860 Rain Train 200
heatman101
Mar 22, 2011 | Nelson Sprinkler: Traveling Tractor
I need the black tips for the sprinkler arms. Where can I order them?
heatman101
Nov 23, 2010 | John Deere Gilmour Traveling Sprinkler -...
Spray arm missing
heatman101
Nov 11, 2010 | Nelson Sprinkler: Traveling Tractor
Nelson Sprinkler:  Traveling Tractor Logo
1,995 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
