The cleaner tape is only supposed to be used after 50 hrs of record /play time , if you are using your cleaner tape alot , you are damaging the helical scanning head and wearing out it,s sensitivity ,
Users have found out that the cleaning tape is like sandpaper made to remove metal particles left behind everytime you run your high 8 tapes , The best way is to send it in to a authorized tascan repair shop in your area , don,t worry there,s always some shops that can be found in your area , they will do a bench test for around 45-50 bucks and tell you what if anything it will cost to fix your problem ! if it turns out to be a dirty helical scanning head they will clen that with 100% alcohol and test it , that they can do usually for the price of the bench test since they do have to remove the cover to see whats going on under the hood! , well the red error light on my machine does come on sometimes when my 2 machines are out of sync, but with shutting the unit down and starting it back up usually takes care of that issue...by the way how often do you use the cleaner?..most da-88 users are totally affraid of even using them !, good luck and if you have any more questions please feel free to email me> glenn
