Question about Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune front load washer and when not in use it slowly fill with water.
  • 55 Answers
Hello.
You have a bad water valve on your unit. It is too weak to close all the way and letting small amounts of water by. You will need to have it replaced. The part number for your water valve is 22003245 if the first two numbers of your serial number are lower than 82. If they are 83 and up order part # 22003834. I have posted a diagram below.
I have a maytag neptune front load washer and when - 161789
Posted on Jul 16, 2009
venexcsd
  • 1185 Answers
SOURCE: My Maytag Neptune washer continues filling with water e
Does it fill when the machine is powered down?
If it does then the fill valve is stuck open and needs replacing
If it does not then you need to check the pressure switch and the air bell on the outer drum which probably has a ball of jellyfied soap in it.
If you take the back off you will see a thin plastic or rubber hose going from the bottom of the drum to a small flying saucer type object.
If you pull the hose off the bottom connection and blow into it you should hear a clicking noise from the pressure switch.
If it clicks then clean out the air bell and refit the hose .
If it does not click then get a new pressure switch
A repairman would test it live but that is not recommended for untrained people
Posted on Jun 22, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
wpcustomer
  • 408 Answers
Creating cleaner, more efficient homes
    Verified Fixya Pro
    SOURCE: My Maytag Neptune front load washer continues to fill with water.
    For troubleshooting assistance please click on the following link
    http://maytag.custhelp.com/app/answers/detail/a_id/2027/kw/continues%20to%20fill/p/293/r_id/108284
    Posted on Jul 17, 2010
    Daniel S
    • 4323 Answers
    SOURCE: Problem with the Maytag Neptune MAH5500B Front
    Hi
    Lr means locked rotor, this issue occurs due to locked rotors, you'll need to check the rotor wiring and windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad as a little power surge can damage the boards. Hope this helps...please post back for further assistance.
    Daniel
    Posted on Jul 17, 2011
    • 6277 Answers
    SOURCE: After a complete cycle the
    This is symptomatic of a malfunctioning (not closing completely) water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
    Take all power off the washer then turn one or the other off and see which one is causing the problem. Sorry but it needs replacing. If it only happens when there is power supplied to the washer, a service call is required to confirm that it is not something else- like the control board not feeding the correct voltage to the valve ;-0(
    If this has assisted you please consider a 4 thumbs up for the rating.
    Thanks and good luck!
    John C
    Posted on Sep 06, 2011
    After a complete cycle the drum fills (slowly) with water leaving clothes soaked.maytag Neptune front loader
    John C
    Sep 06, 2011 | Maytag Neptune MAH5500B Front Load Washer
    The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
    If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
    Washing Machine Problems No Water
    Washing Machine Fix Washing Machine No Water
    heatman101
    Sep 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
    Maytag neptune washer wont fill water
    It is very possible for it to be a valve failur as these machines have a temperature control incommon, It recieves voltatge through the temp control.
    Jan 10, 2010 | Maytag MAH6700AWW Neptune Front-Load...
    Only hot water will fill, cold water will not
    If it is equipped with ATC automatic temp control turn it off and see if if you can get cold if so its the ATC sensor
    Sep 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
    My Maytag Neptune leaks water from the bottom (immediately) as it fills with water
    usually this is from the front door seal going bad remove the front panel and door to replace it
    Apr 30, 2009 | Maytag MAH6700AWW Neptune Front-Load...
    Neptune
    Remove the water hoses from the washer and clean out the filter screens in the water valve.
    Apr 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Tub fills with water
    replace water valve in the washer. Serial number is needed to find the correct part number. It's likely 22003834, but call any parts supplier with model/serial numbers to verify.
    Good luck,
    Vlad
    First Choice Appliance
    Jan 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Maytag Neptune MAH5500B Front Load Washer Logo
    156 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
