Question about Nikon COOLPIX L18 Digital Camera
How to delete all pictures on card, I can not get to the place to select all pictures, Thx JW
  • 285 Answers
Go to the Card Format option in your camera menus... Formatting the card wipes all the data off in one go.
Posted on Jul 16, 2009
Cannot delete pictures from my PNY card
Check to see if you have the lock switch on, this is a small slider on the side of the card. If it's enabled you will need to slide it to unlock and place it back into the computer/camera. You will then be able to delete the contents of the card.
Aug 01, 2011 | PNY 4GB Micro Attache USB 2.0 Flash Drive
I put my memory card into laptop, message says my card is full, and yet i delete my pics from camera., do i have to delete from memory card also, if so how do i do that.
Did you delete the pictures from the internal camera memory and not the SD card? An easy way to solve this problem would be to insert the card into your computer and open up "My Computer". In here you should see your memory card mounted as a usable drive. Open up the SD card, select everything in it by pressing "Control" + "A" and then hitting delete. This will clean everything off of the card. If you want to save the files from the card first, simply make a folder somewhere on your PC and drag all of the files from the SD card into that folder after pressing "Control" + "A". If you are still getting an error stating your card is full after removing them this way you may need to re-format the card or it may be malfunctioning.
Jun 27, 2011 | Computers & Internet
How do i delete pictures from my camera
To delete individual pictures, select the picture in playback mode then press the trash-can button (also marked FUNC).
To delete all pictures, your best bet is to format the card. FixYa is full of people asking how to salvage pictures from cards that haven't been formatted regularly. To format the card, press the MENU button. Use left/right to select Setup (wrench and hammer). Use up/down to select Format and press SET.
Mar 23, 2011 | Canon PowerShot A95 Digital Camera
I have a Panasonic Lumix Model No. DMC-F3 I upload the pictures and movies but one will not go away It says "This motion image cannot be played" I try to delete it and it says "This picture...
First, try to delete the movie from the computer - just navigate to it and select it, and press the delete key. If that doesn't work, use the format function of the camera to reformat the memory card (obviously this should delete everything, including the problem one).
If reformatting causes the file numbering to restart from 0001 and this messes with your personal filing system, you may be able to take one picture, use your computer to change the name of it with the 'rename' function to the number you want to continue from, and then start taking pictures again. (Many cameras will notice the numbered file, and continue the numbering from there; however, I can't guarantee that yours will do this.)
Jan 22, 2011 | Panasonic Lumix DMC-FX3 Digital Camera
How do you delete multiple images from camera?
Are the pictures on a memory card? In that case, you're much better off formatting the card. If you continue to delete unwanted pictures, you'll fragment the card and ultimately you'll have problems. Every day somebody posts here with that problem. Formatting cleans things up.
If the pictures are in internal memory, select Internal Memory Tool from the Setup menu, and you can format the internal memory, deleting all the pictures. My earlier comments hold true here as well.
If you insist on keeping some pictures and deleting others, then go into the index (thumbnail) mode. Press the trashcan button, then select [Select] with up/down, then press *. Select images with the arrows, then press * to display the delete indicator on the selected pictures, Press the trashcan, select [OK], then press *.
May 13, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
I have an aiptek hd camcorder, 1280x720 8 mega pixels,pmp,voice recorder... i cant figure out how to delete the pictures and or videos. are they stored on the card till its full, then change the card, or...
If the images are on the card you select the appropriate pics and then from the MENU select delete. OR you can remove the card and and place it into a card reader select and delete.
Please rate my help++++Thanks for using FIXYA
Mar 06, 2010 | Aiptek PocketCam DV4500 Digital Camera
The lens is stuck in place
I had the same problem. I can tell you that in the "System" menu, there is a place to delete all of the existing photos. You have pictures stored on the memory card and also the capability of storing a limited number of photos on the camera's internal memory. If its in the internal memory, that's when you have to find the system area. If the pictures are only on the memory card, then its easier to delete because you just select "format" and it will format the card and delete all of the photos from the card.
Sep 12, 2009 | Nikon COOLPIX S700 Digital Camera
Importing data from stick to computer - deleting data on stick
Yeah, all you have to do is delete all the pictures on the card. It's easiest to do on your computer, not the camera. Just put the memory stick back into your computer and find all the pictures and select and delete them. If you've already transfered them to your computer then don't worry about it. If you delete the photos off the stick, they will NOT be deleted from your computer so just go ahead and do it.
May 24, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
"Card full", but it isn't full
hello.
On the menu find the "format' option. and format the memory card.
or
also you can connect to the PC and go to my computer and then right click the drive(your camera drive detected by pc) and select the format.
or
also you can empty only the recycle bin of your pc so that every thing will be deleted.
melnavz
Mar 24, 2008 | Samsung L700 Digital Camera
Deleting pictures
pull the sd card out slide bar to not protected mode on sd card itself ok rate this thx nick
Feb 11, 2008 | Kodak EasyShare C613 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
74 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
