Question about Refrigerators
Refrdgerator not staying cold
Our top freezer is staying cold but the fridge is not. There is water leaking in the back of the refridgerator
    President:
  • 1,136 Answers
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Posted on Jul 16, 2009
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
Water leaks from vents in fridge
This could be your heater has malfuncutioned and what is happening is that when you turn it on the freezer is trying to get cold and frost and the heater is staying on and letting things melt very fast and causing a water problem
May 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Apr 08, 2009 | LG Refrigerators
Freezer in nice and cold but refridgerator is not
due to lots of moisture in the air or high humidity it creates extra frost in the freezing unit this creates blockage in the air flow once the ice crystals build up. the freezer is what keeps the fridge at the normal temperature if the air flow between the two are blocked in the ducting then the fridge temperature will rise the best way to solve this is to open the freezer take out the 4 screws in the back panel tilt the panel forward and blow it with a blow dryer till the ice chunk has melted its a good idea to use a towel and on the top self of the fridge to obsorb excess water this can be kinda messy. or you can unplug your fridge for about 6 or so hours. good luck hope i helped. :)
Mar 25, 2009 | KitchenAid KTRS22EM Top Freezer...
WATER LEAKING INSIDE
We had that happening in ours, and so we redistributed the items on the top shelf, The things were stacked high, and though the refridgerator was ok, the coldness wasnt able to circulate like it is meant to do.
Mar 19, 2009 | KitchenAid Refrigerators
Fan running but not keeping cold
check to see if the compressor is running, if not you may need a start kit, (relay,overload) If the compressor is running take the back freezer panel off and check to see if there is a frost pattern, might be out of gas if frost pattern has receeded
Nov 08, 2008 | Whirlpool ET1FHTXM Top Freezer...
Refridgerator not staying cold
hi, have you recently moved it? could be that gas is leaking.
Jan 13, 2008 | GE GSS25JEMWW Side by Side
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
