Question about Maytag MGR5875QDS Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
When I select bake on my gas oven and select 375 nothing happens..... but broil works and so do all the toppers Any suggestions what's wrong or how I can fix it?
    President:
  • 1,136 Answers
Hi, The most common fix is a new oven ignitor. The ignitors go out and will not open the gas valve. Remove the floor panel inside the oven and you will be able to see the ignitor.
Please let me know if I can assist you further.
Vic
Posted on Jul 16, 2009
Top burners work. Bake and Broil do not
sounds like you may have an igniter problem or a faulty gas valve
Dec 11, 2013 | Whirlpool SF368LEP Gas Kitchen Range
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
Whirlpool GS563LXSS: bake and broil doesn't work.
Oven suddenly stopped to work.
After trying to turn on "bake" or "broil" I can hear couple clicks but nothing else happens.
No flame/no gas is coming out.
Mar 19, 2010 | Whirlpool GS563LXSS - stainless Steel Gas...
Self cleaning gas range: Bake and broil will not light up.
the thermal fuse in back is out. sometimes they are resetable
Feb 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
After baking and trying to set time bake a week ago, the range won't turn on at all. Nothing happens when we press bake, broil, convect bake, etc. The clock, lights, fan, timer and cook top still work.
the oven controller in the main service/selection panel has either a bad solder joint on the circuits or the start realy for the oven on the same circuit board is bad and you have to replace the whole panel you cannot just buy the relay
Jan 20, 2010 | Jenn-Air JDS9865BDP Stainless Steel Dual...
GE Profile gas range - Model Number removed by previous owners. Black slide in range with warming drawer - 5-10 years old. Digital oven controls on left side Broil and Bake functions are reversed. When...
Unplug the range.
I would open the control console and locate the BAKE/BROIL terminals on the Oven control. I would reverse the wires,plug the range in and try again.
Sounds to me like someone has changed out a part and wired it wrong.
Jan 03, 2010 | GE Kitchen Ranges
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire conventional oven won't heat up
My frigidaire model is CPLEF398CCB conventional electric flat top oven. Everything is working fine except my oven. When I select pre-heat, broil or bake nothing lid up. No heat on the coil, only fan.Any suggestions?
Jul 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Ge oven jpbp90
Ted, you probably have a bad ignitor. If you have a meter, you can do some checks to rule out the board. Take the back top panel off and on the board you will see four wires..from left to right they should read L1, neutral, broil and bake on the board. Broil and bake will be marked as BR and BA. Set the oven to 350 and press bake, you should have 120V from BA to Nuetral. If so your board is ok. You should also hear a click after pressing bake. 90% of the time it's the ignitor, part number WB13K0004. Be care when testing with live power. Catriver..post back.
Oct 15, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven will not heat to requested temperature
Shaffy, When baking only the bake element should heat. When broiling only the broil element (upper) should heat. Your oven is a Kitchenaid, you have a 5 year warranty on any electronic element or control board. You may have a temperature sensor that is not working right. The oven just might need to be calibrated, the instructions would be in your owners manual. Your bake element might be failing, it would have to be ohmed out. You also need to verify that the bake element is getting 240V. when turned on. Catriver...post back
Sep 07, 2006 | KitchenAid KERC507 Electric Kitchen Range
Maytag MGR5875QDS Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
181 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
