Question about Apple eMac Desktop
Where is the best place to get a replacement power button for emac?
    Problem Solver:
  • 13 Answers
Ebay! Make sure the seller guarantees the
part's compatibly, not DOA and make sure he's
in your country! (just helps with ship time!)
Posted on Jul 16, 2009
I want to transplant emac power supply
Hi Paul, OPen an eMac is staighytforward but a little risky becasue onece the case is open you are exposed to the EHT circuity and the nasty capacitors.
Sit the unit on its screen then undo the large silver allan screws on the outisde of the unit and the screws on the base. Lift off the back of the unit carefully and watch that you dont break the cire connecting the on-off switch. It usually has enough slack so that you can disconnect it safely.Once the back is off you can see what you have to do. - it's not easy though as I remember, the way the thing has been put together is not exactly obvious.
Mar 23, 2013 | Apple eMac 1.25GHz w/ SuperDrive Mac...
Manual for emac 1 ghz power pc
Best place is eBay for parts but you can find all sorts of manuals with Google.
Feb 12, 2012 | Apple eMac G4 Desktop
I have a emac powerpc G4 i cant find how to open cd player no eject button
If you hold down the mouse button, and then turn on the eMac, the drive will pop out, and you can put in a CD. Also, you can hold the F12 button to eject. Even if there isn't a dedicated Eject key on the keyboard, you can eject this way.
Aug 17, 2011 | Apple eMac G4 Desktop
What do I do if every time i turn my emac on there is only a flashing file in the center of the screen and no mouse courser
I have a possible solution, but it would be helpful to know what operating system you have on your eMac. Mac OS X is the Mac operating system. Do you have Mac OS X 10.2, 10.3, or 10.4, for example.
Solution:Do you have your system discs for your eMac or an Mac OS X installation disc? You'll need it to fix the problem. Use the newest disc you have.
WARNING: There is a _slight_ risk of loss of your data (pictures, documents, etc.) when reinstalling your operating system. Backing up your precious photos and other documents is critical!
1. If the eMac is on, hold down the power button until it turns off. 2. Turn the eMac while holding down the mouse button. 3. When the CD/DVD drive opens, put the system disc in (use disc #1 if you have more than one disc). 4. Turn the machine off again by holding down the power button. 5. Turn the machine on while holding down the C key on the keyboard to boot from CD (or DVD). 6. Wait until the eMac boots from your system disc. 7. You should see the install screen. There should be an Options button. Click the Options button. 8. One of the choices will be to do an "Archive and Install". Go ahead and do an "Archive and Install", which will reinstall the operating system but leave your photos and other files. See cautions above. **Do _NOT_ click the option to ERASE the hard drive** or you'll lose all your photos, etc. 9. Once it's all done (expect it to take an hour or more), you should be able to use your computer normally.
Good luck. I hope this is understandable. If you need more help, please post again. *Please rate me if this helped.* Thanks!
Sep 15, 2010 | Apple eMac G4 Desktop
EMac leaky-Capacitors
Sorry, but once a capacitor fails it can lead to other failures on the logic board. Your best bet is to replace the logic board. Due to the price of the logic board and age of the computer, I wouldn't replace the logic board.
It's time to go shopping for a new Mac.
Aug 15, 2010 | Apple eMac G4 Desktop
EMAC is not powering ON
You need a expert. Thank you.
Jun 07, 2010 | Apple eMac G4 Desktop
Apple computer eMac will not turn on.
You wil need a new power supply unit.
May 24, 2009 | Apple eMac Desktop
MAC G4 won't boot - Blue screen appears
Hi Sorry to hear you are having troubles,You will need a firewire 400 cableOK, first thing you must do is reboot the eMac in TARGET mode, this means it will be recognized as an external disk. To get the eMac in TARGET mode, you must be sure the eMac is turned OFF and has a functioning keyboard connected.Power on the eMac and very very rapidly press the ( T ) key on the keyboard, be sure the caps lock button is not pressed. If all goes well, you will see the firewire logo appear larger than life on the screen.( If you are unable to get into TARGET mode, it is highly probable that the mother board of the internal hard drive is damaged and preventing the eMac from entering TARGET mode, sorry, that's the end of the line..)Once you enter TARGET mode on the eMac, connect the firewire cable to your G4 PowerBook, you can do this either while it is running or when it is off and then turn it on.
You should see the volume of your eMac internal hard drive appear on the PowerBook desktop...sometimes you need to open Disk Utilities and repair or mount the drive manually.If this all works well, copy the required files directly to your PowerBook...After that, power off both machines, disconnect them and reboot the eMac using a CD or DVD to reformat and reinstall a new system.
Mar 30, 2009 | Apple eMac G4 Desktop
My emac doesn't power on
unplug it over night and try to power up in the morning
Nov 17, 2008 | Apple eMac G4 Desktop
Removing outer shell of emac
Lift the housing up 4 " pull off the power button cable on the housing side. reverse.
Jerry
May 09, 2008 | Apple eMac G4 Desktop
Apple eMac Desktop Logo
121 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
