Question about Astro Pneumatic 3 Pk. MIG Welder Torch Tip - .023" - 4023, by - Astro Pneum
My welder just stopped welding. It's a Telwin 220 Mig. The fan is still running but there is no noise from the welder and the wire is not feeding. I had only used it for around 30 seconds before it stopped. Thanks Tony
  • 850 Answers
Your feeder may need adjusting or more commonly the tip has tacked itself on the edn cap
keep the line as straight as you can & keep feeder compartment clean!
keep plyers handy for when wire is stuck in the tip
if you need to replace wire spool or a brakage of the wire make sure the wire is free or BURRS b4 you put it in the tube or you will damage the tube!
Cheer Rob.
Posted on Jul 20, 2009
My telwin mig welder feeds the wire just no spark ..frustrating. .any ideas
Sounds like the pcb needs repairing or replacing it may not be giving out the voltage required to pull in the contactor or relay.
Oct 09, 2015 | Welding Tools
Cebora mini mig on trigger no wire feed ,power on?
Cebora mini mig on trigger no wire feed ,power on? - Fixya
www.fixya.com/.../t25810314-cebora_mini_mig_trigger_no_wire_feed
3 hours ago - Question about MIG Welders ... Weld corp mig 100 turn machine on andwire keeps feeding without ... Welder running but wont feed wire etc.
Aug 05, 2015 | Welding Tools
Why does my cmapells haussfield welder not feed the wire correctly (it stops feeding in mid weld then picks back up) and just stop feeding completely after 10 min of welding?
Check the "duty cycle" for your unit. If you try to run it too hot for too long, it will shut itself off to prevent overheating.
Mar 06, 2015 | Welding Tools
Lincon mig stops feeding wire
Been welding for a while, open side, check for proper tension on the feed wheel inside side panel, hit the trigger, if feed motor continues to spin tensioner needs tightened or mig wire may be getting hung up inside main cable lead. If motor is off on off on then its probbably the switch on the trigger getting a bad good connection, hope this helps o and check welding tip on gun end, may need replaced if worn or melted, unscrews.
Mar 05, 2012 | Welding Tools
Would like to if the telwin bimax 182 turbo have stitch timer an where do i find it on the machine?machine is to years old.
Hi there, the Bimax 182 has the stitch weld switch between the wire feed speed control and stitch weld timer, just flick it on and you are in business,
cheers.
Dec 18, 2010 | Atd Tools Welding Tools
I have a lincon 3200 hd. it stoped feeding the wire when i was welding. but it feeds when i pull the triger, till i try to weld again
These welders have thermal breakers in them so if they get to hott the will automatically stop feeding the wire but the fan will remain on, try changing the breaker i think its in the door where the spool is held. good luck]
Apr 13, 2010 | Welding Tools
Astro Pneumatic 3 Pk. MIG Welder Torch Tip - .023" - 4023, by  - Astro Pneum Logo
323 people viewed this question
Top Astro Pneumatic Welding Tools Experts
Bill Boyd
Are you an Astro Pneumatic Welding Tool Expert? Answer questions, earn points and help others
