Question about Panasonic KX-FL511 Plain Paper Laser Fax
Drum replacement required
Replaced drum,need code for replacement
  • bur-1 Dec 01, 2007
    did a rather dumb move, bought another fax machine
    An user who is expert in 3 categories / brands.
  • Panasonic Master
  • 1,362 Answers
Here is the manual for the panasonic:
return the other or now you have two.
Posted on Dec 05, 2007
Konica minolta 185 m2
Clear the counters for drum and developer, Replace the drum and developer, run required process, done, Do not reset without replacing because copier uses the counter if you reset without replace code and image problems will begin. Because copier will think drum and developer are new when in fact there are not and voltages set for new will be working on old stuff.
May 26, 2016 | Konica Minolta Office Equipment & Supplies
Sharp MX-3100; what does DK mean
h r u . DK MEANS black drum life is over need to replace black drum unit or Reset black drum unit counter.
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code07
Then you can select what you want to clear so the bk drum unit
Feb 26, 2015 | SHARP MX-3100N
How to reset m2 error
Have you replace the developer and the drum. First clear the counters for the drum and developer and then replace the drum and developer, then run the required F8. if not the machine will start showing bad copies showing codes. If you clear the counters and don't do anything then the copier will think the parts are new set voltages as required when in fact they are old and will cause problems. So recommend you do the right thing get a tech out to replace the drum and developer
May 19, 2014 | Konica Minolta bizhub C250 All-In-One...
Bizhub 350 printing blank copy
Does you machine say replace PC drum on the control panel if so need to have the drum developer replaced at the same time. The code is dealing with the image unit the drum is one part the developer section is the bottom part or the sensor at the bottom of the image unit is bad. If developer was replaced did that person use a vacuum clean if so then the static electricity from the vacuum clean destroyed the sensor. NEVER USE A VACUUM to remove old toner. Worse case the main board that the sensor feeds is bad. Also when (if the drum and developer where replace did that person clear the counter for developer and drum. Machine works on info from counters to set certain voltages on certain assy. If the counters are not cleared then the copier thinks there is old developer and old drum in the machine and sets voltages for those units when in reality there are new drum and developer . Also after the developer was replaced was the required F8 run. And no prints/fax or copies where made before the f8 was run. When replacing the developer and drum the fax line and the Ethernet cable need to be removed first even used F8 and counters are done in service mode.
Mar 05, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Reset konica drum counter
has it been replaced???????????????????????/
Has the drum been replaced? If not reset code for drum without replacing the drum is not good. Because the copier works based on the counters. If you reset the counters without replacing the require items, then the copier will adjust certain voltages to certain items such as the drum as those it is new because you reset the counters when in fact the drum is old and so you might be codes and image problems.
Feb 13, 2014 | Konica Minolta Office Equipment & Supplies
Devloper reset code
Has the developer been replaced? If not reset code for developer without replacing the developer is not good. Because the copier works based on the counters. If you reset the counter with out replacing the require item the copier will adjust certain voltages to certain items such as the drum and developer system as those there are new because you reset the counters when in fact he developer is old and so mite be the drum which can cause codes and image problems. If the developer was replaced where the counters cleared and was the required F8 checked run?
Dec 15, 2013 | Minolta bizhub 200 All-In-One Printer
Need to reset drum counter on di2510
Has the drum developer and cleaning blade been replaced? If not then the copier will think all three are new and will adjust High Voltages as require. When in reality the they are not new> Causing image problems and service codes. DO it right have it done right, Like clear counters first then replace the parts then run the required F8.
Mar 02, 2012 | Minolta DI2510 Black and White Copier
Error code f70
F70 Error code means Central Control Unit Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
F71 error code meansUser Interface Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
In both the above situations the following things are required to be checked and replaced where required:
1. Continuity of the User Interface harness.
2. Wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving.
Oct 04, 2010 | Whirlpool Duet WFW9550 Washer
I changed the drum but it still reads drum error and i am not receiving faxes. There is a ring so the connections are working. I cant get in to the area where it reads drum set.
Need to know Make and model to be sure.
However, many new machines reset the drum counter by blowing a fuse in the drum cartridge or by recoginition of a new chip in the cartridge. Some require a "Service code" access to reset counter after the drum has been replaced. Need specifics to be more help.
May 11, 2010 | Office Equipment & Supplies
Konica Minolta bizhub Di1811p i get error code C0F32
Need to replace the developer and drum and run required F8 and clear counters prior to the developer and drum replacement
Dec 05, 2008 | Minolta Office Equipment & Supplies
Panasonic KX-FL511 Plain Paper Laser Fax Logo
349 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
