Washing Machines Logo
John Smith Posted on Feb 25, 2016
WM5140W: Fails test mode 3. Motor starts fast spin then stops almost immediately. No further tests available, start/pause light flashes continuously.
Checked brushes - good. Commutator clean and turns freely. No signs of damage to motor. Fitted new control board and heater as old element not heating water. New element doesn't seem to, either! On wash cycle and spin cycle something seems to shut the motor down as soon as it starts. I'm out of ideas. If you can fix this one, Paul, you'll deserve more than a beer.
roberta mackleway
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Feb 25, 2016
roberta mackleway
Contributor
Level 1:
New Friend:
Answers
14
Questions
Helped
3239
Points
47
You need a new motor dude
Testimonial: "Maybe, maybe not, Dude."
I have a whirlpool cabrio and the lid will not lock the light keeps flashing and it keeps making the lock clicking sound
BEFORE ASSUMING THE LID SWITCH NEEDS REPLACEMENT TEST WITH A METER, BUT FIRST TRY TO RESET CONTROL BOARD EVEN RUNNING A DIAGNOSTIC TEST WILL REVEAL THE SOURCE OF THE ERROR.. 1. Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on). 2. Select any one button (except POWER, START, STOP, and PAUSE/CANCEL) and follow the steps below, using the same button: a. Press/hold 3 seconds. b. Release for 3 seconds. c. Press/hold 3 seconds. d. Release for 3 seconds. e. Press/hold 3 seconds. ? If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display. ? If indicators do not display as described above, the press/hold/release procedure above may not have been performed within the time frame necessary for successful entry. Repeat step 2 to ensure this was not the cause. If still unsuccessful, see Diagnostic: Unsuccessful Entry, at right. 3. The test sequence continues by checking for saved fault codes: ? If there are saved fault codes, see Diagnostic: Saved Fault Codes, page 2. ? If there are no saved fault codes, all indicators on the console will momentarily turn off, then turn back on with 88 displayed. After 5 seconds, the Automatic test, below, begins.
http://www.applianceaid.com/pdf/Whirlpool-Cabrio-Waher-WTW6600SB3-Tech-Sheet-W10026634.pdf
TEST #8 Lid Lock Perform the following checks if washer fails to lock (or unlock). 1. Perform Manual: Lid Switch and Manual: Lid Lock tests on page 2. 2. Remove the console to access the machine/motor control assembly. See Accessing & Removing the Electronic Assemblies, at right. 3. Visually check that the P12 connector is inserted all the way into the machine/motor control. ? If visual check passes, go to step 4. ? If visual check fails, reconnect P4 and repeat step 1. 4. Check the lid lock motor winding and switches by removing P12 from the machine/motor control and checking the resistance values shown in the following Lid Lock Resistance table:
TO RESET TURN KNOB 1 FULL TURN COUNTERCLOCKWISE, THEN 3 TURNS OR CLICKS CLOCKWISE, 1 TURN COUNTER CLOCKWISE, 1 MORE TURN CLOCKWISE, THEN HIT START , ALL THE INDICATOR LIGHTS SHOULD THEN LIGHT UP, THEN UNPLUG FROM THE WALL FOR 5 MINUTES THEN PLUG BACK IN , IT SHOULD BE RESET AFTER PLUGGING BACK IN
1helpful
I have an error message f51 on my whirlpool cabrio washer model number WTW7600XW0, What is it and how can I fix this error on my own
F51 error code is a motor rotor position sensor failure or a lower harness problem. You need to check the motor in manual test mode, not automatic test mode. This will check the hall sensors and do a spin test: Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on). Select any one button (except POWER, START, STOP, and PAUSE/CANCEL) and follow the steps below, using the same button: Press/hold 3 seconds. Release for 3 seconds. Press/hold 3 seconds. Release for 3 seconds. Press/hold 3 seconds.
If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display. During the 5 second wait time with 88 showing in the display, press the same button once. You should be in manual test mode. If the button is not pressed within 5 seconds, the automatic test mode begins. The Rotor Position Sensor uses Wash, Rinse, and Spin indicators to detect the three hall sensors. Console can have up to two of these indicators on at the same time when the tub is not moving. Open the lid and rotate the basket by hand. The Wash, Rinse, and Spin indicators should toggle on and off according to the direction the tub is being turned.
SPIN TEST: Make sure lid is down. Press and release: 2nd RINSE or EXTRA RINSE. The lid locks and the lid lock indicator turns on. Press and release; SPIN SPEED, WATER LEVEL, or LOAD SIZE. The motor/basket spins at 23 rpm. Press again, motor /basket spins at 530 rpm. Press again, motor/basket spins at 950 rpm. Press again and motor turns off.
What does error code f 51mean?
http://www.applianceblog.com/mainforums/threads/32879-Whirlpool-Cabrio-UL-F51-Error-Codes
How do I fix a f51 code on a whirlpool cabrio washing machine
SPIN TEST: Make sure lid is down. Press and release: 2nd RINSE or EXTRA RINSE. The lid locks and the lid lock indicator turns on. Press and release; SPIN SPEED, WATER LEVEL, or LOAD SIZE. The motor/basket spins at 23 rpm. Press again, motor /basket spins at 530 rpm. Press again, motor/basket spins at 950 rpm. Press again and motor turns off. This was a cut n paste from a blog on that issue.
HE3 doesn't respond to any button. Time light keeps flashing time. Pause cancel button does nothing, Cycle doesn't start. The only thing that will change is if you push a different mode ie, heavy,...
Unplug the machine for at least half an hour to eliminate the possibility of an electronic glitch. Then upon plugging in back, close the door then push CONTROL/ON (if present on this model). Select the DRAIN/SPIN cycle then select NO SPIN by pressing the SPIN SPEED button. Push PREWASH OPTION four times within five seconds. If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds. C:00 will light up on the display. If the Starting procedure fails, push the PAUSE/CANCEL button then repeat the starting procedure.
In order to advance to the next step of the test procedure, push PREWASH OPTION button two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times. The test program goes from C:00 to C:08 and should flash an error code when a problem is present. Post the code back for further troubleshooting, including the exact model number of the machine.
16helpful
3answers
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Motor control board frigidaire
E59 No tacho signal for 3 seconds in other words sounds like a bad motor
Diagnostic Test:
The diagnostic test is performed by using the Program Knob. To START THE TEST:
? On non-digital display models, turn the Program Knob to start position, Drain/Spin.
? On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that can be rotated 360?, turn the Program Knob to start position, Drain/Spin.
? Press Pause Cancel to turn off LEDs.
? Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons.
1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality.
2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment.
3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment.
4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment.
5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened.
7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble.
8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test).
9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating.
10. Turn the program knob (9) clicks from the start position. The control will signal the last error code.
Exiting Diagnostic Mode
There are two options for exiting the Diagnostic Test mode and returning the washer to normal operation:
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Pause Cancel buttons together for a few seconds until wash cycle LEDs appear. If a situation arises where you cannot exit the Diagnostic mode as described above and the bank of 5 LED?s on the right end remain ON regardless of Program Knob position, a combination of pushed buttons may have caused the control to enter a special factory test mode. Disconnect power to reset the control to return washer to normal operation is this occurs.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
? Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
? Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
? Exit Diagnostic Mode to return the washer to normal operation.
2answers
Control locked
Press the end of cycle signal- button for 3 seconds and it should work..
4helpful
2answers
Service Mode
System Diagnostics
SERVICE MODE
The service mode provides service personnel the
ability to verify the operation of the washing machine.
The service mode can be entered in the middle of
any wash cycle. While in the service mode, the
servicer can start a variety of special service tests.
Accessing Service Mode:
Pressing down the delicates and heavy soil keys for
3 seconds places the machine in the service mode.
Motor speed will be displayed when started. To exit
Service Mode, press delicates and heavy soil keys
for 3 seconds again.
Troubleshooting
December 2004 4 16025861
©2004 Maytag Services
Stage of
Wash Cycle
Advances To
Presoak End of Presoak
Wash Every 5 Minutes of
Wash Time
Spin/Drain Every Step of The
Spin Profile
Rinse End of Rinse
Speed Range Displayed
a) 0-99 rpm 0-99 (actual)
b) 100-999 rpm Speed / 10
Quick Service Cycle
While in service mode, pressing the delicates key
will start a quick service cycle. This will be a quick
check of all systems.
The following steps will be followed.
1. Energize the cold and bleach water valves. Fill to
Low level, then turn bleach and cold off.
2. Energize the hot and fabric softener water valves. Fill
to high level, then turn all valves off.
3. Lock the door.
4. Tumble using 7/3 tumble pattern for 12 sec.
5. Turn the drain on.
6. Spin to 800 RPM using default rates.
7. End spin and coast down.
8. Unlock the door when the RPM is zero.
9. Display a ‘PA’ (Passed) on continuously for 10 seconds
if no diagnostic codes were logged during this
test.
The up arrow if pressed will advance to the next step.
The right most dot will be turned on as an indication
of failure and stay on until quick service cycle test
has reached the end. Any diagnostic code logged
during this test will result in failure of the test, but will
not necessarily stop the test. While in quick service
cycle, the pressing of the hand wash will suspend
the machine at this step for 30 minutes until the
Hand Wash key is pressed again. All LED’s will
flash on and off while the cycle is suspended, or on
hold.
Motor Drive System
To check the system, check the board for proper
output to the motor control. Performing a board
output test does this. Then perform the Motor
Control Board Output Test.
Motor Control Board Output Test
1. Disconnect power to the washer.
2. Remove the front panel and pull the JP4 Connector
from the motor control board.
The following Quick Spin test steps are as follows:
1) Lock the door.
2) Spin to 350 rpm and hold for 6 seconds.
3) Spin to 550 rpm and hold for 6 seconds.
4) Spin to 600 rpm and hold for 6 seconds.
5) Spin to 650 rpm and hold for 6 seconds.
6) Spin to 800 rpm and hold for 6 seconds.
If the Spin key is pressed again during the Quick Spin
test, the current speed will be held indefinitely. Pressing
the Spin key again will allow the quick test to
proceed as listed above.
When the washer is in the Service Mode, the speed
will be displayed as a two digit number or a letter/
number.
Quick Spin Test
While in service mode, the pressing of spin key shall
start the washer in the quick spin mode.
3. Reconnect the washer power cord to supply
voltage. Make sure the door is closed.
4. Press delicates and heavy soil keys for 3 seconds
to activate Service Mode.
Top Beko Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
