Question about Samsung ML-2510 Laser Printer
The paper does not feed into the printer
Paper does not feed. It moves about three inches forward in the tray but does not get caught in the rollers to move through the machine
    Problem Solver:
  • 13 Answers
Sounds like you have a jam!
The jam always hides good!
Look carefully and get back with me!
Posted on Jul 16, 2009
What does E02 mean
PDF]canon printer error code e31.pdf - WordPress.com
https://maitioprolur.files.wordpress.com/.../canon-printer-error-code-e31....
... on Canon. Printer MP287 : E02 E31 Cause : The printer is not connected to the computer ( the printer is ... Canon Pixma MP287 All in One Printer List of Error Codes There ... Cartridge: Canon E31 Toner CANON Printer + Copier + Scanner -.
Aug 26, 2015 | Canon PIXMA Office Equipment & Supplies
Will not feed paper. Can print with manual feed in center of printer, but will not pick up paper in tray. It tries three times and can hear the motors whirring, but then stops trying and the attention...
When you look into the tray with the flashlight, you say the top rollers are spinning, are they touching the paper?
Pull open the tray and while you look from the back with the light, close the tray and see if the paper is being lifted to meet that top roller. Take out all the paper and watch it again. Make sure that the platform that the paper sits on in the tray is free to move up. Sounds like it is jammed.
Also check that roller that isn't spinning. Try to GENTLY rotate it with your fingers. If it does rotate, replace the tray. If the paper in the tray doesn't lift, replace the tray.
Oct 30, 2010 | HP LaserJet 1320 Printer
Does not take paper
If the printer won't "pick" the paper, open the back of the machine and look for torn pieces of paper obstructing the path. The paper should be all the way back against the stop so that the rubber rolls will contact the paper when the paper is lifted up against them. There should be no paper bunched up behind the access door. If the paper is against the stop at the back of the machine and the rubber on the roller wheels is ok (mine has three rubber rolls on the right side and one on the left plus a couple in the middle without rubber) then there is a possibility that the mechanism that moves the paper up against the rollers is not operating. You can observe the paper action with the back off by putting one sheet of paper in the tray. Watch as you press and hold the second button (paper) - the mechanism should lift the paper up against the rollers and feed the sheet out the back (because you have the access door off to view). If the paper is not lifted and taken out, the printer might be repairable by repairing the part that has failed - take the printer apart and look at the mechanism. I doubt that you can find parts for it so if it is not simple repair, it will probably cost too much to repair. The paper has to be far enough into the tray so that the rubber rollers catch it - for 8.5x11 paper, the paper should be a little over an inch from the forward edge of the tray when it hits the stop (the paper guide will be approximately 1/8 inch in from that same forward edge.
Jun 09, 2010 | HP DeskJet 810c InkJet Printer
Having paper jams with my dell 1710 laser printer. Any suggestion?
Hello sir; It depend on where the paper got jam, if jam at the point when paper take off, then you have clean up paper pick up roller or replace it, if jam inside the machine then have to clean up paper feed roller, if jam at the end, check the paper exit senser, make sure it moving freely.
Feb 07, 2010 | Dell 1710 Laser Printer
Feeds ok from tray 1 but not tray 2 which is 11x17. There are slight buffed marks at on the papaer in 4 spots but paper wont advance. marks are about 1/4 inch long
those marks are the rollers trying to move the paper. check to see if your tray 2 is lifting.if it is then replace the feed rollers.
Sep 28, 2009 | HP LaserJet 4mv Printer
Samsung CLP-300 paper feed
Clean the feed roller.
Remove the paper tray, from the bottom there is a grey rubber semi wheel in the middle front of where the paper tray would be. Use a cloth with WD-40, brake cleaner, or lighter fluid to lightly wipe the rubber clean. Put the paper tray back in and it should print.
Jan 24, 2009 | Samsung CLP 300 Laser Printer
Paper jam
This video explains how to resolve a recurring paper jam on your product. It sounds like the rollers on the rear access door may not be working properly and are making jamming the paper as it starts to feed up into the printer? Check the rollers on your rear access door and see if they have some give in them and roll freely.
Sep 27, 2008 | HP Photosmart C7180 All-In-One InkJet...
Paper won't feed
I replace feed rollers when this happens but you guys might want to try a slighty damp rag on the probally covered in paper dust feed roller.
Location underneath with cassette out.
Appearence larger Black Rubber cresent shaped roller inch wide front middle under.
Use damp rag water/metho
Nov 05, 2007 | Brother HL-2040 Laser Printer
Automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
Sep 06, 2007 | Samsung ML 1210 Laser Printer
Samsung ML-2510 Laser Printer Logo
209 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
