Hi the year serial numbers r on the frame under the back cover near the motor take the seat of and the cover lifts of only Velcro holding it on....hope this helps
If you can tell me your vin - or your year I can tell you what model you have. But - if you go onto any parts site - such as cheapcycle.com or partsmonster - you name it - you won't need your 'model' # - just your year. You'd click - Yamaha OEM Parts, then ATV then Year - 1992 - 1998 was the Timberwolf - a lot of parts from the 99 - 04 Bear Tracker will work (just about only changed the plastics and carb in 99 - 04) same engine/transmission/rear end, etc. the brakes also went from drum to disc - but you'd click on the year - and then look - the timberwolf will be right there the 1992 - 1998 Yamaha Timberwolf 250 - I can't remember if they offered a timberwolf 350. If you can tell me the vin or year - like I said - I'll reply with your exact model # - but you can buy and order most parts just by model name and year 95 Timberwolf.
I can't tell you the year but the rear casting number 3970010 is usually a 350cid. Year range 1969- 1985. I if you will run the VIN # found on a pad at the front of the pass. side of the block just in front of the cylinder head it will tell you the info your looking for.
Need the entire serial number to tell you waht year it is...the number you gave only tells what unit it was in the line of production...your bike was the 10,424th built that year. The whole number is needed to give you the full specs on the bike.
The serial number on Carrier units tell you when they were built. The first two digits tell you what week they were manufactured. Digits 3 and 4 tell you the year.
